Tecdiver
Dana
Michigan, USA
2021 F150 Lariat PB
Corporate shill
Makes sense when you consider these vehicles will be at construction / job sites. It's a liability for them to be quiet like that
I hope there's a FORScan switch to disable this...
bigskydu
Big Sky, MT
2021 F150 Platinum 6.5' Powerboost
So I guess we're still in the "no way to disable" situation right now, right?
Knickell
Knickell
Mazda Protege, Ford F-150
Not that I’m aware of. Doubt Ford will put anything into the ForScan coding either.
Dybalr
Ryan
Buzzards Bay, MA
2021 F-150 platinum
There is in fact a setting in ForScan that will disable this. However, I don’t have a power boost. So this isn’t an issue for me.
Dybalr
Ryan
Buzzards Bay, MA
2021 F-150 platinum
These coders and programmers better get on it!
So reading other forums this looks to be something that isn’t currently an option.
It’s it’s own module so unplugging it throws a DTC error. Forscan isn’t going to help this either. At least not at this time. I’ll find other forum I read this on and post shortly.
wayfarer556
Austin, TX
2021 F150 XLT Powerboost 302A
There’s a legal requirement for some kind of noise being made. I just wish it wasen’t so lame.
Knickell
Knickell
I was thinking that would be the case.
jafo
Pittsboro
2021 F-150 Lariat Star white
I suppose if the Powerboost was actually quite while backing up this would make sense. Even in electric mode it's still pretty noisy.
Millionvill3
James
2021 f150
Business owner
I have had it unplugged for about a week now. Only thing is it tells you on startup that the pedestrian sounder needs serviced. No engine codes.
BHunted1
Sumner County TN
If they wanted it to be a backup beeper, wish it was in the back, not front in line with the driver. I'm thinking about wrapping it in foam.
Cessnadog
Tim
Minnesota
2021 F150 Lariat
This!!
I have a golf cart with a back up beeper on it and I thought a piece of tape across the face would just pull it down to a reasonable volume. It turns out one piece of electrical tape was actually too quiet for what I wanted. I have to think there is a easy solution here.
Knickell
Knickell
Good point. It definitely comes from the engine bay.
