Yours is not the problem axle configuration:I took off the passenger side rear center cap and saw this. Is it ok? Couldn’t get the driver side off.
Looks like typical surface rust to me.I took off the passenger side rear center cap and saw this. Is it ok? Couldn’t get the driver side off.![]()
Replace the OEM battery with a quality aftermarket battery (Duralast Platinum, for example) and your deep sleep issues will likely go away. That worked for many of us.I agree and I sort of feel that way sometimes with the deep sleep mode I get occasionally. I think to myself what if the truck won't start because I have a bad battery. I keep it on a trickle charger but I get frustrated sometimes having to do it since I didn't buy a Lightning.
Maybe I'm stubborn, or just cheap, but I don't think I should have to buy a new battery for a truck that is only a year and a half old with 3,700 miles on it. I've taken it to the dealer twice to have them look at it and each time they tell me it's fine. For now I've been dealing with it but it's the one gripe I have with a truck I otherwise love.Replace the OEM battery with a quality aftermarket battery (Duralast Platinum, for example) and your deep sleep issues will likely go away. That worked for many of us.
yup. I get it. I can only say that or solved the problem for quite a few of us whose battery also tested “ok”. For me it was less time, cost and frustration just to swap it myself.Maybe I'm stubborn, or just cheap, but I don't think I should have to buy a new battery for a truck that is only a year and a half old with 3,700 miles on it. I've taken it to the dealer twice to have them look at it and each time they tell me it's fine. For now I've been dealing with it but it's the one gripe I have with a truck I otherwise love.
Did you ever get to the bottom of this??UPDATE: I can rule out a broken axle bolt. Glad to know that's not the case.
In the meantime, are there certain areas of the underbody I can inspect to see what's causing the squeak when I hit bumps? It's metal on metal and sounds like it bounds and rebounds with the road undulations. It's audible at very slow speed and minor bumps. For instance, rolling through a gravel lot makes it squeak. Rolling through a paved lot makes it squeak. It's very sensitive.
I've kicked the tires, jumped on the running boards, and generally banged around on anything that wouldn't cut me underneath the truck and I've not been able to pinpoint the source.
Truck is still scheduled for a dealer visit in 2 weeks, but I'd be happy to temporarily fix the squeak, if possible.
I could sneak up on people in parking lots before this started.![]()
