tilefordude
Derrick
Delco, PA (YUP)
2021 f150 xlt 302 high 3.5 eco
Tile Setter
I got a fail on the IPMA update. I’ve been running out checking my laptop periodically and we made dinner and I went out laptop screen was black I had to log back into windows and had a fail. I was about 2 hours into the update too. Truck seems dead. I have 14.4 amps steady in the app on the battery. I have it on a solid charger. So sad…
Don't take this wrong, but you are taking the same risky approach as many dealerships do.
The tab is running at $150 an hour, yet they aren't dedicated to the procedure. Going to lunch or walking away and doing something else.
It's a calculated risk, I understand. But I'm not going to walk away during a firmware write to an expensive component on the truck. Fortunately, it appears that Ford has made it pretty difficult to totally brick a truck even if the user inadvertently interrupts the procedure.
Still, I advise some worthy caution. :)
tilefordude
Derrick
Delco, PA (YUP)
Tile Setter
It’s not dead. Make sure to set your laptop to never sleep when plugged in. Shut the doors for a bit and start over.
I just did that I will retry the update tomorrow after work. Thank you
Kanuck
Winnipeg, Manitoba
Retired Electrician
Did you have your negative connected to the the battery post or to a frame ground? Looks like the truck didn't see the charging. The negative needs to be on a bolt head or non painted frame point.
tilefordude
Derrick
Delco, PA (YUP)
Tile Setter
Thanks for your input. It’s hard for me to sit there for 3-5 hours and watch but now that I’m aware I’m going to make it a priority. I can’t commit to that particular update again until tomorrow. But I’ve made a few changes to my laptop and I’m hoping it doesn’t goto sleep again on me when I attempt after work tomorrow.
tilefordude
Derrick
Delco, PA (YUP)
Tile Setter
I’m on the bolt head that’s pictured in the first post. You can see that the app says 13.6 volts. That warning makes no sense if you read it but maybe I’m getting sleepy.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Just a thought....good night.
Big Dog Daddy
New Jersey
As long as all 3 lights in the lower corner of the fdrs screen are green, continue.
Take a book or a tablet or second laptop and enjoy some leisure time while you are performing the updates.
Make some popcorn and put on a movie and let the whole family sit in the truck with you? :)
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
Anyone seen this one ? ?
Several times, but I forget what FDRS version it started in. It's just another screen for dealer techs to ignore that was put in solely due to their ignorance and failure to read other prompts.
Based on your stats, the only update I'd question starting is the IPMA due to the state of charge stat and length of time that update takes. If your charger/power supply keeping up during the process on shorter updates though, you'll be fine.
tilefordude
Derrick
Delco, PA (YUP)
Tile Setter
? right now where I am. I’m throwing in the towel for the night. I’ll attempt tomorrow after work thanks again
