zacko11288
It showed a successful update after about 10 minI just got notification of this update as well. How long does it tke ? I just accepted it.
how long does the update take ? I just got it too ...Am I the first job 1?!?? Have to click download now and will get back to ya’ll!![]()
does it need a battery charger connected ?I didn't time it, but whenever I let my updates go via FDRS I would let the truck sit for 20 minutes.
Nodoes it need a battery charger connected ?
mine was also successful !!It showed a successful update after about 10 min
Understood, Thanks!iT WILL AUTO DOWNLOAD IF YOU HAVE IT SET TO AUTO UPDATE. i TINK AT THIS POINT IT IS SAFE TO ALLOW AUTO UPDATES TO BE ON AGAIN.
wHEN ON MANUAL YOU WILL HAVE TO SELECT TO APPROVE AND THEN DOWNLOAD.
I am assuming this 3.5.2. was the GWM update is this corect ?Understood, Thanks!
CorrectI am assuming this 3.5.2. was the GWM update is this corect ?
I hope so.Apparently it’s job 1 ‘21 ver 3.5.2 update day. I got mine too this afternoon. Per Jesse’s advice, I’ll turn auto updates back on. Hopefully the days of crap OTA’s are behind us.
Tonesto is aware. Ford changed some of its code and he is working to fix the issues.Anyone that uses the scriptable widget seen this under OTA updates? The last two OTA updates for 2021 job 1 came through without issues.![]()
