Dynamic LED headlights pin out diagram
Jimi
Portland, OR
Ford F150 Platinum Powerboost BAP 7.2KW Gen
If your 2021+ F150 model truck comes factory equipped with LED headlight assemblies than your raptor grill light or side vent lighting install will requires a slight modification to the install shown in the video for halogen equipped vehicles.
http://support.f150leds.com/en/articles/5520946-installing-raptor-lights-or-side-vent-lighting-on-a-2021-f150-with-factory-led-headlights
The only change is simply where you connect for ground and power. Instead of connecting to a side marker light plug, you will be connecting at your headlight assemblies harness plug to the wires as indicated below.
driver side - black/yellow = ground grey/blue = power(DRL)
passenger side - black/grey = ground Violet/white = power(DRL)
Ford F-150 Dynamic LED headlights pin out diagram Captur
Bowhunter3D
Randy
NY
Electrican
custom auto works store.com has the same connectors but come with a waterproof plug and if you call them they will add a wire for the turn signal if you want
M_trumble
Springvale, ME
2021 Ford F150 Limited
Soldier
For those that installed the vent lights from F150 LED’s. Does connecting the wiring to DRL wire leave the vent lights on all the time?? I’m trying to only have them turn on at night with the parking lights. I have a Limited with 502a package
M_trumble
Springvale, ME
Soldier
I too am trying to add side vent lights to my 502a powerboost. Which wires do I tap into so they stay on with the ambers between the headlights?
Did you get an answer to this? Do yours only work at night?
JJohn
California
Ford F150 Lariat CC PB
I ended up having a shop do it for me, while getting other work done on it. They are on as soon as I approach the vehicle and go off after a minute or so of non operation.
kingsfan33
2022 F150 Lightning Lariat
Anyone have the pin out color / diagram for the headlamp molex plug for the f150 lightning?
thanks
Gabes
Jon
Hugo, United States
2018 F150 2.7 EB, 2021 F150 PB
Machinist
Anyone looked at the 2024 headlight connector to see if the pins are the same? Thinking about putting in some Side vent Marker DRL lights. Can easily connect to the regular running light, but will have to tap into the blinker wire somewhere else to get it to fully work.
Ford F-150 Dynamic LED headlights pin out diagram 1720552796201-mh
