adenture_Ty
- #16
I did this to give it a test and the bottom beams are angled up so when you have them in line with the tops, the bottom beams to overshoot the tops considerably.
Well I notice 2 but yeah because Diode has you stagger the top projector and low projector you will see that. Im NOT quite sure why they have you do that. Other dual projector/quad projector systems I've used have the projectors all linked together and they are all aligned. So when you move them up/down all the projectors move together so the cut-off stays consistant. But Diode has a separate alignment for the top and bottom one offset by a few inches. If it bothers you just make them equal on the wall.
