DTC's After LED Reflector to Projector Swap Solved!
SnareDrum
Connecticut
2022 f150 lariat
Hey all,
I completed the LED Reflector to LED Projector swap this week. I'm getting some DTC's in FORscan and I'm not sure what to do in order to resolve them. I discovered these after driving the truck for the first time. I placed the truck into reverse and got the "Reverse Brake Assist Not Available See Owners Manual" message. This led me to do a diag and I found that I have a couple DTC's from the HCM (although I've read this is normal), the IPMA and the PSCM (which I'm assuming is related to the DTC with the IPMA). If anyone has encountered these DTC's before and knows how to fix them please help! I tried recalibrating the IPMA in FORscan and that hasn't resolved the issue. See the attached DTC's for details. Your help is greatly appreciated!
===PCM DTC None===
Successful DTC reading, no error codes found
Module: Powertrain Control Module
===END PCM DTC None===
===OBDII DTC None===
Module: On Board Diagnostic II
===END OBDII DTC None===
===APIM DTC None===
Module: Accessory Protocol Interface Module
===END APIM DTC None===
===SODR DTC None===
Module: Side Obstacle Detection Control Module - Right
===END SODR DTC None===
===SODL DTC None===
Module: Side Obstacle Detection Control Module - Left
===END SODL DTC None===
===ATCM DTC None===
Module: All Terrain Control Module
===END ATCM DTC None===
===TRM DTC None===
Module: Trailer Module
===END TRM DTC None===
===DSP DTC None===
Module: (Audio) Digital Signal Processing Module
===END DSP DTC None===
===RGTM DTC None===
Module: Rear Gate/Trunk Module
===END RGTM DTC None===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===TCCM DTC None===
Module: Transfer Case Control Module
===END TCCM DTC None===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
===TCU DTC None===
Module: Telematic Control Unit Module
===END TCU DTC None===
===RTM DTC None===
Module: Radio Transceiver Module
===END RTM DTC None===
===DSM DTC None===
Module: Driver's Seat Module
===END DSM DTC None===
===PDM DTC None===
Module: Passengers Door Control Unit
===END PDM DTC None===
===DDM DTC None===
Module: Drivers Door Module
===END DDM DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===HCM DTC C1A03:14-0B===
Code: C1A03 - Left Front Height Sensor
Additional Fault Symptom :)14):
- Circuit Short To Ground Or Open
Status (-0B):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Headlamp Control Module
===END HCM DTC C1A03:14-0B===
===HCM DTC C1A05:14-0B===
Code: C1A05 - Left Rear Height Sensor
Status (-0B):
===END HCM DTC C1A05:14-0B===
===HCM DTC U2101:00-0B===
Code: U2101 - Control Module Configuration Incompatible
Status (-0B):
===END HCM DTC U2101:00-0B===
===HVAC DTC None===
Module: Heating Ventilation Air Conditioning
===END HVAC DTC None===
===GSM DTC None===
Module: Gear Shift Module
===END GSM DTC None===
===PSCM DTC U023A:00-2E===
Code: U023A - Lost Communication With Image Processing Module A
Status (-2E):
Module: Power Steering Control Module
Freeze Frame #1:
-STEER_ROT_SPD: 0 1/min - Steering Pinion Rotation Speed
-STEER_PIN_ANG: 123.30 ° - Steering Pinion Angle
-SSHFT_TQ_S2: -1.0 Nm - Steering Shaft Torque Sensor #2
-SW_ALIGN_OFSET: 25.20 ° - Steering Wheel Angle Alignment Offset
-ECU_POWER_SUPPLY: 14.2 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 42 °C - ECU Internal Temperature
-MOTOR_CURRENT: 23.60 A - Motor Current
-EVENT_TIME: 39325152 s (Sun Jun 11 12:33:38 2023) - Event time
-TOTAL_DISTANCE: 33700 km - Total Distance
-OUTDOOR_TEMPERATURE: 28 °C - Outside temperature
-IGN_CYCL_CNTR: 82 - DID EE03 Ignition Cycle Counter
-IGN_ON_TIME: 175000.00 ms - Ignition On Time
-FINAL_MTR_TOR: 252.0 Nm - Final Motor Torque
===END PSCM DTC U023A:00-2E===
===PSCM DTC U0415:00-2F===
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module 'A'
Status (-2F):
Freeze Frame #1:
-STEER_PIN_ANG: 123.70 ° - Steering Pinion Angle
-SSHFT_TQ_S2: -0.4 Nm - Steering Shaft Torque Sensor #2
-SW_ALIGN_OFSET: 27.00 ° - Steering Wheel Angle Alignment Offset
-ECU_POWER_SUPPLY: 12.4 V - ECU Power Supply Voltage
-EVENT_TIME: 39324985 s (Sun Jun 11 12:30:51 2023) - Event time
-OUTDOOR_TEMPERATURE: 86 °C - Outside temperature
-IGN_ON_TIME: 7000.00 ms - Ignition On Time
-FINAL_MTR_TOR: 0.0 Nm - Final Motor Torque
===END PSCM DTC U0415:00-2F===
===ACM DTC None===
Module: Audio Control Module
===END ACM DTC None===
===BdyCM DTC None===
Module: Body Control Module
===END BdyCM DTC None===
===SCCM DTC None===
Module: Steering Column Control Module
===END SCCM DTC None===
===IPC DTC None===
Module: Instrument Panel Control Module
===END IPC DTC None===
===GWM DTC None===
Module: Gateway Module A
===END GWM DTC None===
===IPMA DTC B1578:78-2F===
Code: B1578 - Digital Park Assist Camera Vision System
Additional Fault Symptom :)78):
- Alignment Or Adjustment Incorrect
Status (-2F):
Module: Image Processing Module A
===END IPMA DTC B1578:78-2F===
===BCMC DTC None===
Module: Body Control Module C
===END BCMC DTC None===
SnareDrum
SnareDrum
Connecticut
2022 f150 lariat
Yes. I made the changes to the HCM and BCM that were outlined in the instructions that came with the harness made by Ryan Broderick. I also made changes outlined in a spreadsheet posted by @dolsen for the glare free option.
SnareDrum
SnareDrum
Connecticut
2022 f150 lariat
Update! Fixed the DTCs! What I did was go into service under the IPMA and did a 360 view camera calibration. The camera on the grill must have been misaligned during installation. All my DTCs related to the PSCM and IPMA are fixed. Hope this helps someone else
mdomicolo
Matty
North Jersey
22’ F-150 Lariat 501A
Union Electrician
So, you have no codes at all? Not even the (3) DTC’s that everyone says is normal when switching from the reflector LED to the Projector LED headlights?
SnareDrum
SnareDrum
Connecticut
2022 f150 lariat
None whatsoever. I also installed the height sensors which I believe are those DTCs that others have.
mdomicolo
Matty
North Jersey
Union Electrician
Would those be the sensors near each shock?!
mdomicolo
Matty
North Jersey
Union Electrician
Okay so you’re not talking about these then..
Ford F-150 DTC's After LED Reflector to Projector Swap Solved! IMG_5616
Ford F-150 DTC's After LED Reflector to Projector Swap Solved! IMG_5617
dolsen
KY
2022 Rapid Red 701A
Nah I don’t have ccd. I ordered the two sensors you ordered.
What I ordered looks exactly like what @mdomicolo showed. That’s the rear only though. It doesn’t look like he posted the front sensor
