DRL Issues
Skibz
California
2021 F150 XLT Sport 4x4 3.5 Eco
Partially out passenger side DRL on quad beam LED headlight. I know other threads have associated this issue with a previous bad BCM update, but what ended up being the remedy here? Is replacing the module the only fix? If so, what does that entail? I can't get into the dealer as they are weeks out and can't offer loaner vehicle. Would appreciate any guidance.
2021 XLT 3.5 Eco
VIN 1FTFW1E84MKD08344
Ford F-150 DRL Issues 20230530_102839
Ford F-150 DRL Issues 20230530_102845
Warranty issue, see dealer for replacement.
Est1983
Clinton
Dallas , Tx
2021 F150 XLT
What ended up being the problem ? Was it a module or actual bulb ? I have same issue going on and of course have to wait a week or two to even see the dealer ?
Skibz
California
Still hasn't been to the dealer. Apt was over a month out which turned out to be a blessing as now I am having a frozen infotainment system about every single time I drive. Will be taken to dealer in a couple of weeks.
KBKEITH
No bulbs here. It’s an LED cluster with a coupled to a light guide. LED failures are rare so I’d be curious to learn the issue. Seems like one other member here has the same section of DRL that’s either dimmed or failed.
Mustang och
Omar
Mexico
Tremor 2021
Worker
I have the same problem on my 2021 temor , did you get it fixed?
indiana-f150
2021 F-150 XLT, 302A, 5.0, 4x4, White, SuperCrew
2021 XLT 3.5 Eco
Did you ever get this figured out. Having an issue w/ my DRL as well.
Skibz
California
Yes. The dealer thinks it was caused by a previous bad BCM update. They were pretty vague about the situation which makes me think they didn't actually know what caused the issue.
Anyhow, they had to replace the entire headlight assembly. I'm already at 75k miles to which my extended warranty covered it with a $100 ddeductible. I was told standard warranty would have covered it so your dealer should replace it.
indiana-f150
Thanks for update.
Was the alleged BCM update one you installed yourself?
Mine’s out of warranty, so no luck for me there. It’s going in next week for them to take a look at.
Skibz
California
Update was OTA. I pushed back on the dealer on paying deductible since it was Fords own software bug to no avail. Took 3 full days just to diagnose and replace headlight with the part in stock...what a joke.
indiana-f150
Yuck!! Mine’s going to the dealer on Monday if I can’t make progress before then.
One last question I’ll leave you alone…when did you have it replaced? Curious how long you’ve been driving it since it’s been fixed.
Skibz
California
DRL had been out since June 2023. Was replaced Sep 29th 2023 and have ~7k miles driven since replacement without any issues.
I work in the oil fields and the truck is put thru the ringer no doubt. The only issues I've had have been software related and phantom battery drain.
Good luck!
indiana-f150
Good luck!
Thanks for the info!!
BlackWolf
Alain
Miami
Ford F-150
PM
Good morning guys.
Happening to me now,I’m only 20k so I still under warranty,The other day I saw another Ford with the same problem, anyone have more or new info about the issue? I thought it was just a fuse.
Thank you
Good morning guys.
Thank you
Not a fuse, dealer issue.
