That's where I'm leaning towards. Window seal by the B pillarHad the exact same thing happen to me for the first time yesterday on the driver side. Backed off just slightly on the window being fully closed, and the noise went away. Wouldn't that indicate its an issue with the window seal and not the door?
Same issue here. green dotted liner/seal rattles at full close then go away if you drop the window down for an inch or less. I can touch and find the exact spots that radiate based on the exterior wind's angle of attack in motion.Had the exact same thing happen to me for the first time yesterday on the driver side. Backed off just slightly on the window being fully closed, and the noise went away. Wouldn't that indicate its an issue with the window seal and not the door?
where you able to solve it with a fix? I thought I was close but I popped the sunroof today in vent position and boom there it was until I cracked the window down then up again.Same issue here. green dotted liner/seal rattles at full close then go away if you drop the window down for an inch or less. I can touch and find the exact spots that radiate based on the exterior wind's angle of attack in motion.
I use the 303 Products rubber seal treatment or nextzett gummi pfledge on all the weatherstripping when I detail the truck and the noise is still present.Just watched this video. SOLVED: DOOR NOISE from car completely gone in minutes: SMARTDrive
Suggesting applying tire dressing on certain sections of the door weatherstripping does the trick.
Also, notice the F150 owners in the comments.
Haven't tried this yet, but let's hope this cures the issue.
Any more info on the “tubing” fix?Just watched this video. SOLVED: DOOR NOISE from car completely gone in minutes: SMARTDrive
