Do our F150 really need mud flaps?
Pelican
2024 F-150 Lariat (502A) Supercrew POWERBOOST
Financial Management
do our F150 really need mud flaps? if so, do all four wheels or just the rear?
IMO, yes. I purchased them from weather tech. They keep a lot of dirt and grime off the front half of the truck and off the running boards
Pelican
Anyone know anything about this? What is it called, whats it's purpose? And do you have a name or number for what you replaced it with?
Me too Davexxx. Here's the part #'s for anyone that needs them.
Ford F-150 Do our F150 really need mud flaps? Screenshot_20230503-131250_Gmail
Kanuck
Winnipeg, Manitoba
Retired Electrician
i see you're a retired electrician...i'm no where near a retired electrician but i do know being an electrician can wear on people! theres only so much 277V one can take!
seriously though, that was my thought process and how i kinda felt about mud flaps until i put them on and through their paces haha but seeing as they do serve a function i'm ok with them now haha
Lol.... Good to hear...BTW... being in Canada...we don't use 277....we use 347 and 600.
amschind
Adam
'21 F150 SCrew 4x4 Powerboost
Physician
I got the Ford parts store Ford branded Gator ones. They're basically a big thick piece of rubber with a stainless backplate. I like they way they look, though it screams "work truck". The big benefit to me is that they just flex in response to stuff hitting them, i.e. "the Earth", so they are more tolerant of off-roading than a piece of rigid plastic.
Sneezy
Alex
Blueberry$1
2022 F150 XL
Check your local laws, but many states require them on all light duty, heavy duty, and commercial trucks. Definitely applies to commercial trucks across all 50 states, but many states require them on light duty trucks as well.
As a former truck driver, the rule was they have to be at least as wide as your tread and hang down past the center line of the rear axle or lower.
redline
Calgary
2025 f150, BMW M3,VW Atlas
In Canada it law here as well, but how many trucks I see without them , a law that is barely enforced…
  • Like
Reactions: 780
It's a law for larger trucks everywhere but smaller pickups are exempt.
My newly installed mudflaps have done the job this week keeping the road gunk off sides of truck with all the rainy weather. I have added them to every truck I've owned.
WhiteLightningnshitshadow
Lead Engineer
I keep going back and forth as to whether or not I like the look of mudflaps. My stock tires (275/65/18s I think) actually seem to fit nicely under the truck and don't seem to kick up much, but I've only had it off-road once in the two months I've had it.
Kanuck
Winnipeg, Manitoba
Retired Electrician
sheesh! thats freaking ludicrous!
I should point out, those voltages are in industrial and commercial systems, residential are 120/240. where I worked for the last 20 years there was 2 services supplying the plant - one at 25,000 volts and one at 66,000 volts. Both systems were stepped down to 600 volts and lower.
Kanuck
Winnipeg, Manitoba
Retired Electrician
It is enforced in Manitoba. Not on 1/2 nd 3/4 tons, but over that it is.
crazywayne311
Wayne
Hampton Roads, VA
CTMO
i gotcha. nothing to scoff at thats for sure.
i did residential for a tiny bit so thats 120/240 here as well. i did mainly commercial 3 phase systems at either 120/208 or 480/277.
now i'm messing in power generation. most the plant is 480 and up. our switchyard is 234kV. a little much to be around if you ask me haha
Also, people need mud flaps
HeadBanger
Ron
Finleyville, PA
2021 F150 XLT 5.0
Add me to the 'all four' club. Wheel liners and flaps were amongst the first mods I did.
jiggadog
Ontario
F-Series
i'm not an electrician, but worked a summer for a relamping company changing out lights/ballasts in big box department stores. i got a 277V shock one time only and that was enough. one of the worst feelings i ever experienced.
i'm a believer in the mudflaps. put them on every truck.
