Do our F150 really need mud flaps?
air2mag
Indiana
2022 Platinum
I’m in on the mud flaps. I got zapped by 400hz one time when I was in the Air Force. Never want to do that again. I’m
crazywayne311
Wayne
Hampton Roads, VA
CTMO
i'm not an electrician, but worked a summer for a relamping company changing out lights/ballasts in big box department stores. i got a 277V shock one time only and that was enough. one of the first feelings i ever experienced.
i'm a believer in the mudflaps. put them on every truck.
yep, but hit by 277 twice in my life and i vividly remember both instances haha
ALSO, WHEEL WELL LINERS! DO IT
780
Todd
edmonton
Calson
Monterey CA
At a minimum the use of splash guards at all four wheels along with running boards protect the sides of the truck from rocks tossed up by the tires. They also keep the truck a lot cleaner.
Mud flaps are more important if towing a trailer or is using very aggressive "mud" tires. These used to be standard equipment on Toyota trucks but now even with their trucks one needs to add them after purchase.
I problem for me is that my 2022 truck came with factory side steps that are much narrower than the usual running boards and provide far less protection for the sides of the truck and also are quite slipery when wet. They are the primary defect of my truck.
The popa
Carl
Calgary ab
22 F150 powersource
do our F150 really need mud flaps? if so, do all four wheels or just the rear?
In my case in Canada yes. The ice and snow in the winter gets caught up in my rear bumper and stops my rear sensors from working
Gooner5643
Pa
21 Lariat 5.0, e92 m3 6mt
I removed mine within 1 hour of ownership. Can’t stand the look of them
  • Like
Reactions: 780
MHT150
New Hampshire
23 F150 xlt
Major airline
Not a big fan of them but I did put the Weathertech ones on front and rear. Help quite a bit up here in New England.
diambo4life
OKC
2022 Lariat Screw 4x4
Assassin
I have them on my truck. Love them. They keep crap off of the sides of my truck. My truck is not even driven when it's wet outside so I hate driving through water and having traces on my fenders etc.
Ford F-150 Do our F150 really need mud flaps? 0R5A1750 (2)
Ford F-150 Do our F150 really need mud flaps? 0R5A1751 (2)
Ford F-150 Do our F150 really need mud flaps? 0R5A1754 (2)
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
I was on a beer run yesterday after work and had to drive through a drying puddle to park. I could tell as I was leaving the front tires were caked with mud and stones, and the sound on the road as I was leaving confirmed it. I got to the next stop and there was no mud at all on the running boards or up the side of the truck. Just confirmed that they're a good addition
tfstx50
Tom
Indiana
2023 F150 STX 4x4
i have all four ford plastic things, used points
i used to use weather techs, but these seem to work and are supported a bit better in the rear wheel area
they are surprisingly flexible, yet strong
they do keep a good bit of crap off the sides and out back
I just purchased the Ford front and rear flaps for my '23. I notice though that on the rear, the trim piece only has the one hole for the Christmas tree. Wondering if the flaps would sufficiently hold with just the one screw and the mounting bar or do I need to pull that entire trim piece off and drill another hole? Anybody with a '23 had that experience and care to share what you did on that when you mounted the flaps? Thanks.
Mtnman1
Tod
2022 F150 RCSB FX4
All trucks should have at least rear flaps. It stops rocks from hitting vehicles behind you. Should be mandatory.
Fronts are nice to keep the sludge/snow/rocks off the truck.
I have never owned a truck without all 4.
oncechance
Indiana
Drill the hole. I had to do this on my 2022.
BUDXR7
Massachusetts
2023 XLT 302A PB SCREW 4X4
You have AT tires on a truck that’s not even driven when it’s wet out? I don’t get it.
