Ajzride
- #31
This confuses me. If you are tied directly to the aux battery under the rear seat, and are still having issues, how could this be truck related? Unless your aux battery is going bad and the voltage is dipping under load?
I would try this same test with the battery isolated from the truck completely, or get a LifePo4 that can fit in the same spot and try it again. The lifepo4 will basically hold its voltage until it is dead, then the BMS should cut it off.
So your question prompted me to do some testing.
With the Aux battery connected to the truck, it's at 14.34v
With the Aux battery disconnected from the truck, it's at 12.94
I connected the starlink directly to the aux battery while disconnected from the truck. Fired up and worked perfect.
I then connected the aux back to the truck and connected the starlink to the positive and negative of the aux battery. it still work
What is different? Before, I connected my 12- to the post on the positive cable after the 125AMP fuse and the 12- to a seat bolt instead of directly to the battery.
The seat bolt ohm'ed to ground perfectly fine, so I don't know why it wouldn't work. Perhaps @Gros Ventre hit the nail on the head and I am missing something (I did it ohm it after his suggestion).
Next step is to add-a-fuse to the power port and see if it will power from that circuit while grounded straight to a battery.
