Climate Control Power Button
ranorris2
Ryan
Prosper, TX
2022 F150 PB Platinum BAP FX4
Yesterday I enabled the unreal sync theme and glare free lighting, after doing this I noticed I am unable to turn off my AC when the truck is on. It could have been that way before these changes, I don’t know for sure.
Anyways since the hard button didn’t do anything I added the soft button on the screen and found I can turn it off that way.
Does anyone have any ideas if this is a software problem, hard button problem, or maybe a fuse blown? Any help troubleshooting would be appreciated.
Thanks.
ranorris2
ranorris2
Ryan
Prosper, TX
Forgot to mention it’s a 22 Platinum so it has the auto climate control.
ranorris2
ranorris2
Ryan
Prosper, TX
Well I got it working again with a good ole fashioned frustration smack.
I assume it’s a loose connection on the backside of the climate controls. I guess if it happens again I’ll see how difficult it is to remove from the dash to see if it’s worth fixing myself or dealing with the dealer.
Borchelt
Tom
Boise, ID
2021 F-150 XLT, Powerboost Hybrid
Depending on where you wacked it, it might be a loose fuse. Issue with 150's since 2021 . I had several fuses barely seated in the passenger fuse box and under the hood. Easy fix if that's your issue.
