Can you set a default drive mode?
snyce1
Steve
Schenectady,NY
The problem is it always defaults to Normal. With the powerboost it will stay on electric quite a bit more when your in eco mode, which is great around town. Its not a bad thing, but I am just lazy and would prefer it just hold the mode till I change it.
I have a 21 . To get eco from normal i rotate to left 3 clicks . Firat activates dial. The next 2 get me to eco. Always goes back to normal on key cycle .
RJL1400
Big Red
New York
formerly had 2008 Toyota Tundra
Also, do you have to select a mode every time you start the vehicle or does it default to the mode it was last in when it was last turned off?
I have put my truck in eco mode then shut it off, got back in later and it will ask me if I want it to stay in eco mode and then you hit ok. This is on the dash display and the question pops up but goes away quickly
Oxford_Powerboost
Austin
Northern Virginia
2023 F150 Lariat 5.0
The freakin' recirculate won't even stay on if you key off the truck! You expect Ford to let you stay in the same drive mode?
When I first got the truck, I would change into Eco mode EVERY time I drove it as I left my neighborhood. Once, I overshifted into one of the 4X4 only modes and it turned the part-time four wheel drive on while I was driving. I had to stop the truck and turn it off to get it back into 2WD. I was going straight and at low speed, so it was no big deal.
Why stop? Just switch it back to eco and it’ll go back to 2WD
Heavishot
Kerry
DFW, TX
2021 Platinum F-150
Or press the 2WD button and it will switch out of 4x4 even if you're still in Sport mode.
Pedaldude
Arizona
I stopped because I was about to run out of road before a 90° turn. I actually had to turn the ignition off and on again to get back out of 4X4 because it didn't want to with any of the drive modes or the electric shift on the fly buttons. It's not good for the drivetrain to be in 4X4 on pavement in the dry and it's also not a pleasant driving experience, which I know from an old Jeep Grand Cherokee that I had to drive which had something worn out in its AWD system. The tires were like fingers on a chalk board every time you had to park the thing.
I miss the physical shifter of my first truck, where I could get 4X4 within .2-.5 of a second every time. The ESOTF takes an eternity in comparison and doesn't always engage.
XLT regular cab doesn't have the 4A transfer case as an option, so Sport is always RWD when it comes on. I would have gotten the 4A transfer case, LED headlights and opening rear window if I could but Ford won't sell them to reg. cab owners at any cost. If I want any of those things, I have to add them myself.
Rockman5159
Rocky
Marion SC
2021 ford f150 FX4
If I have mine in sport mode and shut it off,when I restart it asks if I want to teturn to sport mode. Not sure about the ECO mode
RJL1400
Big Red
New York
It goes back to normal mode
DVT413
Los Angeles
2021 F-150 Lariat
Along this same topic, the center of the driving mode knob can be pressed. What does this do? Does it lock the driving mode?
tc429
Tim
ohio
2019 lariat chrome 3.5 - 2022 lariat sport 3.5
For those of you that have your trucks already, can you switch the truck to Sport mode while it is in motion, or will that hurt the transfer case? Can the truck be in motion while a “4x4 Shift in Progress” is happening?
I have a Sport mode on one of my other vehicles and it’s nice to just be able to turn it on and off as needed.
lariat-up with '4A' mode can shift on the fly- dunno about the 4H while over certain speeds
jeffcrum
Lake Saint Louis, MO
Computer programmer
Nope. It locks my rear locker.
juicepower
Dan
atlanta ga
2021 F150 XL STX 4x4 VELOCITY BLUE
Integration Engineer
My 2021 I found if you turn it off for a short time less than 3 or 4 min then start it back up it will ask if you want to remain in the old mode and even keep the cluster set in the last setting. I really wish this would just stick to the last setting. I dont understand why it defaults after long periods of being off. Seems like a simple fix that people would love.
DVT413
Los Angeles
2021 F-150 Lariat
Sorry for being green here... what does that mean? That it locks your rear differential? And would it lock the rear dif in every single mode? It's a little confusing to me.
jeffcrum
Computer programmer
No problem.
Yes and yes.
Kanuck
Winnipeg, Manitoba
Retired Electrician
It locks the diff...not good on pavement.
bruor
Adrien
Ontario, Canada
2021 F-150
IT
I just updated all modules in my truck using a VCX nano, are of them was for the instrument panel.
Since updating, I've noticed that I'll get a prompt to return to eco mode even if I leave the truck from 3pm to 8am the next day.
