https://www.f150gen14.com/forum/thr...ctory-33s-vs-lt-34s-tires-fixed-course.19977/and you don't share the light weight E rated tire? please share - interested
Item 28840692 34" on size chart at WILDPEAK A/T4W | Falken Tires is the C rated tire I have on Method 316. I am not unhappy with them but do wish they weren't so heavy. I kindof wonder if I could have gotten away with item 28840115 35" on my leveled MY23 PB. Its just a hair lighter, E rated, and gains a half inch clearance.They do make a D load, but no C that I've found
Yeah I avoided any of the Falken Wildpeaks. (AT3 or AT4) they are way too heavy. I went with the Goodyear Ultraterrain in 285/65/20Item 28840692 34" on size chart at WILDPEAK A/T4W | Falken Tires is the C rated tire I have on Method 316. I am not unhappy with them but do wish they weren't so heavy. I kindof wonder if I could have gotten away with item 28840115 35" on my leveled MY23 PB. Its just a hair lighter, E rated, and gains a half inch clearance.
Makes sense but keep in mind something that'd pop an SL has irreparably damaged the E so do be careful and inspect the tires post such driving.We bought E rated General grabber X3 for towing, for off road/ Forrest service roads.
We were able to lower the pressure for the 3500km of gravel roads in the North west territory as well as Alaska. This was for comfort and side wall protection from the shale.
I run “E” tires on my 98 chev k1500 and have done so for years.So, If I understand your statement correctly, the more PSI in the E rated tire, the smoother the ride? I have E rated tires on a Jeep Wrangler I use for farm use (why - I bought the used Jeep that way). Right now the PSI in the tires are around 30. I've heard to run them that low for a smoother ride but holy cow, I feel every rock on a dirt road. It's rough.
They will improve handling while towing and are more puncture resistant.Why would you need E rated tires when the load capacity of SL rated tires are higher than the axle weight rating?
E.G. I have 275/60r20 Mickey T Baja Bosses STD. Each tire has a load capacity of 2679lb @ 44psi. My Rear GAWR is 3800lb. Doesn't that mean I have almost 1600 pounds of leftover capacity on my rear tires at full load?
WARNING! Please note that size-for-size, LT-metric tires require higher air pressures to
carry equivalent loads of P-metric tires and that any failure to adjust air pressure to achieve the
vehicle’s load requirements will result in tire fatigue and eventual tire failure due to excessive
heat build-up. Due to the higher PSI requirements of LT-metric tires they may not be suitable for
replacing O.E. P-metric tires because of the ride harshness that results from higher PSI
requirements
