Aliass24
Looks good but you have your front reservoir bracket upside down. Just flip it around so the reservoir is tucked up closer to the frame. My truck is a bit lighter than yours but with the testing I have done on 95% pavement with rough patches and potholes, the best setting for me has been the low speed set at 5 clicks in and high speed fully open anything high speed that I’ve tried just seemed a tad stiff other than hitting stuff really fast.Finally got the fronts installed. Overall not horrible job . The passenger side of a powerboost is a bit of a PITA getting the last nut on top but it’s doable as others here have said. Getting the bottom of the factory strut out takes more effort than I thought as well. My upper control arms didn’t come apart but I was able to find a tool to make it work. The dealer gave me the wrong nuts for those as well so that was a bit of delay. All the nuts are nylock type so you should be putting new ones on as you’re not supposed to reuse them.
Ride wise, I’ve left them at setting “3” so far but have only driven it once last night so may play a bit yet. Rides better than the stock that’s for sure, less bouncy , more controlled, firm not hard.
