Bed or receiver mount crane?
Davexxxx
Davexxxx
MO
Well, its here, so can't complain about delivery delays, since I only ordered it yesterday and in good condition, so there is that. If you've got a 1/2" box end and a piece of scotch tape, assembly is a snap. All nylock nuts, is always nice.
It lifted my 225lbs. with no problem.
Its actually pretty nice.
The cons.
The cable is really stiff and I don't doubt it'll be a problem. I'll probably replace it with a much shorter length of sheathed aircraft cable and it'll be fine. I might still have some laying around somewhere. If not, I'll cut it to a more manageable length and see how that does.
It swivels easily, so you want to be fairly level, left to right.
Is it wiggly? Yep. A shim in the receiver hitch, will take out a good chunk of it. There might be a few other tweaks but for now, since I don't have the tote yet, coolers full of water will have to do.
powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
The cons.
PICTURES ?
on the amazon page it looked less than a tight fit on a receiver hitch
is there room on the winch to use flat nylon 2Inch strap vice cables?
Davexxxx
Davexxxx
MO
According to the flow meter on the hose, this is 23.6 gallons of water @ 8.33 = 196.5 + 41 for tools and 10lbs. for the jack, = 247.5 plus whatever the coolers weigh. Another 10? More or less, the same as the tote I'm looking at will weigh full. And being shorter, will be a much easier and safer load than this is.
Ford F-150 Bed or receiver mount crane? 20240407_143013
Ford F-150 Bed or receiver mount crane? 20240407_142953
Davexxxx
Davexxxx
MO
And no, I wouldn't recommend hooking to the grating. I just did it this time, in this highly controlled, laboratory grade experiment. ;)
powerboatr
Excellent ?
powerboatr
Did front wheels come off the ground?
Great test
How easy does it fold down to store ...etc?
Davexxxx
Davexxxx
MO
These 3 pieces just slip together.
If you needed it more compact, its just 2 bolts to remove the lift arm, from the platform.
Ford F-150 Bed or receiver mount crane? 20240407_160121
powerboatr
Pretty slick.
Thanks
Walter Townsend
Walter
Nelson, BC, Canada
2021 F150 Lariat FX4 Off Road Fishing Edition 5.0
Owner Operator Starlight Tool Services Ltd Millwright/Welder/Machinist/Electronics tech
