Bed light switch doesn’t turn on the bed lights
fieldstrong18
Ryan
Mooresville, NC
2021 F-150 Lariat
Home Inspector
My bed mounted switch for the box lighting doesn’t seem to be working. The box lights will turn on when I’m using the Zone lighting with both the controls on the screen and with the FordPass app. But when I open the tailgate and push the button the lights won’t turn on. Am I missing something? Does the truck need to be on for the lights to work?
Kanuck
Winnipeg, Manitoba
Retired Electrician
No...faulty switch maybe. They should work truck running or not.
Way2qk4u2c
Michael
Austin
2022 F-150 2015 Mustang GT
Network admin
I have the same issue but i just checked and mine don't even come on if i press unlock or the button on the console, it does come on only for the zone lighting.
jeffcrum
Lake Saint Louis, MO
Computer programmer
Check that fuses are properly seated. Many have found loose fuses.
Might save you a trip.
Way2qk4u2c
Michael
Austin
Network admin
I checked all my fuses and I even jumper the switch pins to complete the loop and the lights still don’t come on. I think it has to do with the BCM not turning them on. Checked forscan and it shows enabled. Very strange indeed
jeffcrum
Computer programmer
Just throwing it out there. Glad you checked!
Beef_Stew
Aaron
2022 F150 XLT sport CCSB 5.0
Auto Body Tech
Did you have a spray in bedliner done? It’s possible they pulled out the button and forgot to connect it after
Way2qk4u2c
Michael
Austin
Network admin
Nope. The truck is brand new and I picked it up from the dealer few days ago. Truck has 25 miles on it as of today lol.
aaexpert
nh
22 f150 platinum
This is a known problem, no solution. Mine still has this issue even with a new light, switch, harness, bcm,fusebox...its a mystery and still not working. It happened immediately after one of the many dealerships attempts to fix the radio screen going black randomly and all they did was software updates. Worked fine for months since day 1.
Way2qk4u2c
Michael
Austin
Network admin
Finally fixed my lights. I went back into forscan and changed "lincoln experience" to disabled (under BCM) and now my switch in the bed turns the lights on!
toquain
Tommy
Sulphur, La
2022 F150 Lariat
Hi there, Michael! Go ahead and send us a private message with your VIN and dealership info, I’ll look into this for you. Thanks!
I am having the same issue with the bed lighting for my 2022 F150 Lariat. I purchased the vehicle April 31, 2022 and it was delivered this month. It was supposed to come with the bed lighting and didn't. I had the order the lights and switch and i installed myself. It was pretty standard plug and play. The lights do not come on when the switch is pushed, however the tailgate light does come on when the switch is pushed.
Thanks,
Tommy
Vin# 1FTFW1C51NKE59149
Bolton Ford
Lake Charles, La.
64Wing
2014 Fusion Titanium, 2022 F150 SCREW Lariat 502a
Aviation
Thanks,
Tommy
Bolton Ford
Lake Charles, La.
I ordered mine without the bed utility option. Too much coin for lights and other stuff I didn't need. I just wanted the lights and not the other stuff but that wasn't an option. So I installed the factory parts (two light assys and the switch). When I pressed the button the high lamp (by the top brake light) came on so I knew the hot wire from the kick panel to the BCM was there. That's when I knew I just needed to do a few changes in forscan. Voila! They work!
Check this thread out:
https://www.f150gen14.com/forum/threads/2022-lariat-cargo-light-wiring-harness-parts.8683/page-8
