Site said that one won't fit the 2021 F150 XL w/ 5.0I’m going to put in an everstart from Walmart, 4 yr warranty!
https://www.walmart.com/ip/EverStart-Platinum-AGM-Battery-Group-Size-H8-12-Volt-900-CCA/40647529
It’s a larger than factory battery, the figment has been confirmed to fit!Site said that one won't fit the 2021 F150 XL w/ 5.0
It does fit, I got the Ford AGM 850cca (dealer warranty as they installed it) This is the biggest that will fit in the battery tray. Make sure to get the Battery insulator cover - PN in link below.Bigger is better. H8 should fit on every truck without PB.
