Battery maintainer
Onula
Oli
Northern Ontario
2021 F150 Powerboost Lariat
Hello,
I know there were several topics about this and I read them but none offered specifics for powerboost that I’ve seen.
Will leave my car in a closed garage for two-three months. Manual says disconnect many members say battery maintainer.
should I buy two maintainer for both batteries one at the engine bay and one at the backseat ?
Which one should I buy there are so many local car shop told me this one https://a.co/d/dPmOdYy
But have so many models and capacities. Norco genious 5A
If I am disconnecting. How can I disconnect them? Just pull off neg?
later I saw that the backseat one is smaller one I thought it was full size - lol first time opening that box.
Thank you!
Mszczewski
Milwaukee, WI
21 F-150 Lariat Powerboost
I run one 10amp Noco maintainer hooked up to the primary starting battery. That battery is connected to the small under-the-seat battery; thus, they are both maintained. The 5amp is probably more than enough if you park it for that duration.
Calson
Monterey CA
All you need is one for the starter battery. I bought the Shumacher SC1355 for my truck and like that it has a simple connector for the battery clip harness so I can leave it attached when removing the maintainer from the truck.
