Anyone seen this ?
madsend81
East San Diego County, CA
2023 F150 PB XLT Sport 4x4, 157" WB
That's what I read too. Apparently the metal used in the valves became brittle when exposed to the heat from combustion in the cylinders and started cracking.
musman
musman
Dan
Montreal
2021 F150 , 2022 Edge ST, 2017 Shelby GT350
I thought i read that it includes pretty much all ´21 and up models ! My Edge ST will be in the bunch if they ever do a recall. I’ll stay tuned !
madsend81
Apparently they changed the material in the valves in Oct of 2021, so late 2022 and 2023 model years are not affected.
https://fordauthority.com/2023/10/nhtsa-opens-investigation-into-ford-ecoboost-engine-failures/
”fordauthority.com" said:
Back in October 2021, the manufacturing process for these intake valves was changed, and newer versions of that part are made from “Silichrome 1,” which is less susceptible to this problem. Ford notes that the defective valves tend to fail early in the life of the engine – typically within just a few hundred or thousands of miles – and also informed the NHTSA that most of the resulting engine failures have already occurred.
WhiteLightningnshitshadow
Lead Engineer
PPK
PPK
OKC
2022 F150 502A, 1947 CJ2A, WK2 Limited
Engine code needs to be AB... that is up front drivers side of engine.
Hopefully not another recall but my job 1 would definitely be on the list.
