Question is this engine done
hellobbbb987
Brian
#FUkSm1YzWy6m
2015 f150
Based on this picture of metal in the pan I was told this engine was done. Got another one but I took the one that came out apart a bit turbos look fine the timing chain was new everything looks good so far can't find where the metal would have come from so far would that much in the pan be enough for a mechanic to say it's done
Ford F-150 Question is this engine done signal-2021-03-18-123624
Ford F-150 Question is this engine done 20210506_172850
Ford F-150 Question is this engine done 20210506_172828
Roady
Cory
Northeast PA
2021 F150 XLT FX4
Information Technology
Yea that thing is smoked, along with the turbos.
hellobbbb987
Brian
#FUkSm1YzWy6m
2015 f150
Everything on it looks fine I wish I would have taken pictures of turbos they look like nothings wrong but the oil pump does not move as freely as it should makes noise and their could be possibly that it could be from their 200000 on truck and maybe the previous owner changed the timing chain cause that looks Brand new the truck made noise when starter their was no metal in the oil filter my buddy said the oil pump was done so I got someone else to put it in when he dropped the pan he said it was done and anyone that seen it since being removed has told me it looks fine the mechanic got me to replace it for no reason I guess I have to keep taking it apart to find where the metal came from
hellobbbb987
Brian
#FUkSm1YzWy6m
2015 f150
The bearings look fine their no metal in oil filter or turbos
Their was just the metal in the pan the timing chain looks brand new along with tensioners ad guides and the oil pump definitely wasn't working but the truck was never ran after the oil was changed for longer the 25 seconds and was fine before the oil change
hellobbbb987
Brian
#FUkSm1YzWy6m
2015 f150
Even if it ran fine the one day turned it over for 25 seconds it sounded rough turned it right away 25 seconds is actually an over estimate of time
