Android widget
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
Can't wait for it to hit the Play Store and try to install it on my Chromebook! The process to sideload in ChromeOS it's a mess compared to on a phone.
Kanuck
Winnipeg, Manitoba
Retired Electrician
I just download the file to your phone and email it to your self ...get your email on your chrome book and install it.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Version 2022.05.12 just uploaded. The changes are described in the change log. I wanted to make everyone aware of my plan to release a version of the app (still free) on the Google Play store in the next one or two weeks. The only internal differences between the versions will the Google Play version won't have checks for app updates (since that will be handled automatically), the package names will be be different, and the icon will display a different vehicle.
Once the app is officially up on the Google Play, I'll either post here to make it known and/or put a link in the change log.
Thanks again for all your work in developing this app for us android users.
imnuts
Dirty Jerz
Facilities Engineer
It doesn't work that way for ChromeOS and side loading apps.
UGADawg96
JAX, FL
Has anyone had refresh issues on Pixel phones ? I have it set to refresh in 30min (default), but I even try manual refreshes from the menu and it rarely updates. Right now the last refresh was 1hr 34min ago. It seems like maybe a permissions issue ? I thought maybe it was something with an older version of the widget as this was one reason I removed it a while back as it would go days without refreshing, but just tried the current version and it's doing the same thing.
kennelh
kennelh
Louise and Ken
Northern California
2021 Mustang Mach-E, Premium RWD
Has anyone had refresh issues on Pixel phones ? I have it set to refresh in 30min (default), but I even try manual refreshes from the menu and it rarely updates. Right now the last refresh was 1hr 34min ago. It seems like maybe a permissions issue ? I thought maybe it was an older version of the widget as this was one reason I removed it a while back as it would go days without refreshing, but just tried the current version and it's doing the same thing.
Did you turn off Battery Optimization?
Go to Settings, scroll to Battery Optimization. If it shows On, tap on it and find the app (select All Apps first), and select No Optimization.
UGADawg96
JAX, FL
It was on, turned it off. Did manual refresh. Still showing 1hr 49 min ago.
UGADawg96
JAX, FL
After about 10 manual attempts, it finally updated. I'll walk away and see if gets past 30 min again... unless you suggest any troubleshooting.
kennelh
kennelh
Louise and Ken
Northern California
Triple-tap on "Last refresh" and it will display when it got the last update and when the last alarm went off (usually they are the same, but if there was a network issue the alarm time will be later). If those aren't changing, then there's some other problem. You'll need to turn enable logging and upload the log to GitHub (let it run long enough to do a refresh).
Be aware that the last refresh time is the last time the vehicle reported an update, not the last time the app did a refresh.
UGADawg96
JAX, FL
Widget is still showing last refresh of 1 min from just like when I posted a few mins ago that it finally updated, but triple tap says 15:47 EDT, which was 8 mins ago, so this tells me the widget itself isn't updating the UI versus a data issue.
UGADawg96
JAX, FL
I've turned on logging in case you need those, but does the logging capture when the widget updates the UI text ?
UGADawg96
JAX, FL
Both last update and last alarm are both 15:47, but the display still says last refresh 1 min ago.
AAWhyte
Alex
Fort Walton Beach FL
2022 Lariat 5.0
PM
I am having the same issue. It's like the widget text does not update, right now it shows last update was 1 hr 27 minutes ago, but when I triple tap it displays at the bottom that it was updated 4 minutes ago.
kennelh
kennelh
Louise and Ken
Northern California
If you turn on logging, it will write info to the log when the widget update is called. I can then compare those to the data read from Ford's servers.
