Doughecka
Usa
2022 XLT 302a PowerBoost SuperCrew
:LOL: haha thanks!
Checking that connector is super easy, just pop off the side panel and reach in and disconnect it quick to see if the wires are there or not.
If you do all your research, and looks like you definitely have already, it should be pretty simple for you once you wrap your head around all the Forscan changes needed. If you like puzzles, I shouldn't've made it so easy and made you go through and figured out all the values that needed changed on your own! Like Jesse and me had to do months ago when we forging the path for all this and figuring it out by trial and error haha.
Strange about your HD radio, there are some values in the ACM and APIM to change, you might just try to enable them to see if you have it, just not enabled for who knows why.
Well, didn't even have to remove the connector... So I'll need to do plan B and built a harness. And run it from point A to point B.
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? 20221124_195558
XLT22
GA
2025 STX 200A
What is your IPMA part number by chance? The ML3T-14G647-CV in my 302a has me scratching my head.
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
The IPMA doesn't make a difference, any part number should work, it just depends if its pre-wired or not for the CCM.
Doughecka
Usa
For those that have added this, did auto wipers get enabled as well?
Mtntrls
Graham
Oregon
2024 F150 702A
I added the rain sensing wipers when I upgraded my steering wheel to heat. I needed a new steering wheel stalk, the rain sensor, and some forscan changes. Seems to work well.
Also, I posted my cruise control switch with the distance adjustment in the market if anyone is looking for one.
Aron
Aron
Civil Engineer
Has anybody successfully done this? Outside of Jesse, who enabled it by upgrading a whole slew of things that the rest of us probably won’t be doing.
Doughecka
Usa
Gotcha, I didn't realize it used special wipers... Figured it just used the camera, and wiped when it couldn't see clearly. Like a human would. ?
Doughecka
Usa
If you go through this thread, there's reports of a few others doing this, by just adding the sensor, and forscan changes of course.
Aron
Aron
Civil Engineer
Sorry--I thought this was a different thread (about adding Park Assist). Which, as far as I can tell, we're still investigating what needs to be changed to add.
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Ya, I don't blame ya, we kinda have a mess on our hands, but all the good info is here about it so this is the place to be. There is also another thread where we are trying to sort out the active park assist deal and how easily that can be added and/or enabled.
Pointman
Wisconsin
2022 PB 302A
Looking at the middle connector I believe my truck has the four wires that are needed. XLT 302A W/360 cams
It is a powerboost so I'm not sure if the bumper harness that is listed as working (ML3Z15K867MA) is the harness I need. I read people on here say to compare their VIN to truck VIN with the options the are adding, but I don't know how or where that is done. If anyone knows or could help me figure out which harness I need to order that would be great.
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? IMG_20221127_172109054
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? IMG_20221127_172126906
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
Yours is prewired so you should be good there. Do you have parking sensors or no?
Pointman
Wisconsin
2022 PB 302A
superfordman, no truck does not have the front sensors. But I do have the pedestrian sounder in the front if that is tied to that harness.
XLT22
GA
2025 STX 200A
I was finally able to locate a 2.7 Lariat VIN built with the adaptive cruise, and I think I have all the parts coming. ML3Z-15K867-JA is the bumper harness I found from the donor VIN with no parking sensors.
For what it's worth, my 22 302a did have the wires populated at the IPMA. I have the B&O system if that helps.
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? 1669687886818
superfordman
Troy
NE CO
2024 Raptor 801A
Precision Ag Guru
I did a bit of looking and I think ML3Z-15K867-MA is still the harness you need. I'm not 100% on how the speaker ties in, looks like its a separate harness that connects someplace. I'd have to double check for sure, or if someone with access to PTS can look it up quick to see exactly how and where that speaker ties in.
ML3Z-15K867-JA isn't the correct harness, you would need ML3Z-15K867-MA, you have the same setup as me pretty much.
