Adding Co-Pilot Assist 2.0 with Forscan?
jasoyeung
Jason
Virginia Beach, VA
2022 XL STX
Solution Architect
Can bus spec is 1 twist every 25mm (~ 1 inch). Is it he can't see enough wire length under the conduit to see how much twist there is? Or there isn't any twist?
Do you want to chance it and have issues later? Maybe have to do it twice? Or do it correctly the first time?
The communication between the CCM and IPMA literally prevents a collision between yourself and another vehicle if you don't intervene yourself. I would want the correct wiring setup that carries those messages at a rate of 2 MB/second to have the best chance to do it's intended purpose.
What's the twists purpose? "CAN bus cable consists of a pair of wires known as CAN high and CAN low (indicating high and low speed, respectively). Both wires are twisted tightly together to ensure that electromagnetic interference affects the signal in both wires uniformly, limiting errors." It's so if there is interference, both wires have the same interference and thus the CAN signal difference (High vs Low) is unchanged.
$0.39 per foot from this great small business in Illinois:
https://www.playingwithfusion.com/productview.php?pdid=107
To confirm, I will need 4 wires. 2 untwisted and 2 twisted?
I'm looking at the wiring diagram, here. I'm planning on ordering twisted wires from the link you posted in this post.
For wiring from the CCM to the IPMA does this sounds right?
CCM > CCM Connector(?) > Splice > Wires* > IPMA
? The wires on the CCM connector don't look pre-twisted. Do I need to twist them? or will splicing to twisted wires be ok?
*Wires will need pins attached to connect to IPMA
I plan on taking pictures and documenting this for those interested in doing it. Waiting for my tax return before ordering parts... haha
KTM753
Attached is that diagram showing wires twisted. Do they need to be twisted all the way to the plug or terminals? Probably not but the closer the better.
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? Screenshot_20240319-104913~2
jasoyeung
Jason
Virginia Beach, VA
2022 XL STX
Solution Architect
Kind of confusing, no? Because there is also that wire twist indication at the CCM. I'm gonna dig some more through this thread... Maybe I missed something.
Steve-O
I think this one is c242b and it has the right numbers open. Just want to make sure.
Is there a trick to getting the terminal to seed in the slots? Do you have to force them in there, does orientation matter?
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? 1000004405
Yes, orientation matters. They only feed in 1 way (properly), the top and bottom rows of the connector are 180 degrees out of phase of each other.
If you look at the connector there's typically a little piece of metal for retention sticking out (or it's a recess like shown below) from the pin itself, this goes Up in the top row, or down in the bottom. Opposite of this little tab is typically 2 little leg looking things (not always) that are running parallel to the wire orientation. The crimping prongs are also pointing "up". If there's no obstructions or an odd crimp, it should slide in and you will hear the connectors plastic tab click down into it. Post clicking it should be able to wiggle just a little bit. I use my wire hydraulic crimps to slight smash a paper clip creating a flat head area on it about 1/4" long. Then I sand the edge a bit to create a chisel point. When you push the pin into the connector and then slide the paper clip tool on top of the metal connector it should disengage the plastic clip and then the pin will slide right out. I've been able to make every wire connector tool needed with cheap medium sized paper clips.
Ford F-150 Adding Co-Pilot Assist 2.0 with Forscan? 1711747813738-l0
Steve-O
[/QUOTE]
Yeah, they aren't fitting in there without force and I don't want to force it... I hope I have the right terminals. They feel fat for the slot. Any advice?
It's a shame, as that's the last part of my install before forscan programming.
Also the directions for the sccm for the wheel switch are not too clear. Not sure what to change for that input.
Create a removal tool and inspect a factory set pin to verify you've got the proper ones. Just be sure to put it back in the right hole. Your crimping may be faulty if you don't have a crimping tool specifically to fit those pins. If you just smashed the tabs over, it may be too wide. It must remain within the profile of the pin area. If you flattened it out that may be the problem.
Steve-O
Am I supposed to crimp or do something with the terminals before inserting?... I was under the impression they were ready to just drop in. I haven't flattened or adjusted the terminals at all yet.
Steve-O
Fyi, I did get the Ford terminals everyone was linking here.
Sounds like you have pre-made cable. Beats me, no telling what they did. Quite a few terminals that look the same but are very much not the same. They have different retention points.
Steve-O
(DU2Z-14474-BA)
These are the ones I got, they feel a bit fat, should I flatten them a bit? Just feels wrong to have to do that. Or I wonder if there are smaller terminals?
Update wrong pins, should be CA not BA
mrtull
Jeffrey
Socorro, NM
2024 XLT PB 302A in Darkened Bronze Metallic, 2023 Ranger Lariat Tremor
Teacher
I'm almost in the same exact position ('22 XLT 302A w/removed nav, no 360 cams), and I'm strongly considering going through this process. Only difference is I have a PowerBoost, which sounds like is a bit more crowded behind the bumper, so I'd probably have to remove the bumper to install the CCM.
To summarize my findings thus far:
Thank you so much for this summary. I read thru the entire thread just to make sure I didn't miss anything but this is perfect for me. I also have 22 XLT 302A w/ 360 cams. I've verified I have the wires in IPMA so i should only need the one wiring harnesses. I owe you a ? , although @Jesse-Infotainment saved me heartache by pointing out 22s were missing chips for front sensors, so I owe him a ? too! Heck, I owe a beer to so many posters , it'd be easier to buy a round for thr whole forum.
Cheers!
Oakstone
Victoria, BC Canada
22 F-150 PB XLT 302A
Cheers!
Am getting set to do the CCM install in the next month. I have ordered front sensors and the harness that supports them since I figured it was a good time to do it.
Seems like there's varying reports of being able to use them. @Jesse-Infotainment we're sure that 22's don't support front parking sensors? I don't want to order/paint the sensors if they won't ever work.
Thanks!
