tbinmd
IT's actually two different things, the adaptive headlights is using matrix beams of the LED headlights (turning segments on and off). The dynamic is the motors actaully turning of the projector in the headlight housing. You would think the heads lights are still the same, but you would need to compare part numbers.So would one assume if you have dynamic bending as part of your build that it should house the same equipment to move the headlights once enabled for the adaptive part?
