2025 Wireless stick on Keypad
caperj
James
Calgary
2022 F150
Voip Engineer
Anyone know of a way to program with Forscan, all I am finding is FRDS required.
tsigwing
DFW
2025 F150 PB
Another reason to get the hardwired door mounted one
Porpoise Hork
Bret
IT Sys Admin
You should be able to use Forscan to link it with updates to the BCM As-Built address 726-37-01 (*xxx xxxx xxxx) Just not sure what to change this to for it to work. May also need to update the APIM As-Built for the option to show up in Sync to be able to access it and enter your factory code.
While it may be a little more work than a peel and stick pad and slightly more expensive the hardwired keypad looks so much better unless you're planning on sticking the pad in the gas door or something like that. Plus most 14th gens have the harness in place for the keypad so you just need the B-pillar kit and 45 min of time.
nvabill
Virginia Beach, Va.
2022 F-150 XLT, Jeep Wrangler Rubicon
Damn. Why my Maverick dealer charges 200 to install
You need to buy it through Ford Accessories at the link I shared. Not sure how it works but you pay upfront for the price shown. I had one put on a new Bronco, you pick a participating dealer and that’s what they charge.
CiTY HuNTeR
Dan
Savannah, GA
2024 F150 Lariat PB
You are at luck. My dealer said its price was wrong. It's for sticking it to your door. Coding is different price. Or my dealer was lying
discothan
SW Michigan
2021 F150 XLT
Probably lying. I bought OEM tow mirrors from Ford Accessories and added on the install cost from the site. (took advantage of 20% off parts) I brought the truck in and switched the mirrors out and realigned the 360 cameras. No labor charge on top of what I had paid online. This happened back mid 2021.
nvabill
Virginia Beach, Va.
Sounds like your dealer is clueless, not all dealers agree to install. My local dealer did not, I had to travel 45 minutes to another dealer. It’s all spelled out when you purchase the unit, you then have to choose a dealer who does Ford install.
nvabill
Virginia Beach, Va.
Yep, exactly the way the security door code install went for me.
PBXL
Somewhere
2021 F150 XL Powerboost
Only certain dealers do installs from Ford Accessories, but you get to select from a list when you make your purchase.
