2024 Plat BC 1.4 Upgrade
tompken
tompken
Tom
Miami, FL
'24 Plat F150, '25 GT Mach-e
Yea, but it's not the same ABG. Notice on the Mach E it starts with a T which is a 2026 part number. The both firmwares may end with ABG, but they are very VERY different.
Yep, was more of a trivia than anything :)
My 100A charger should arrive tomorrow... I might pull the trigger on updating the mache. Most updates seem to be lightweight except for that driver camera something something that took 1h+ on my F150.
Interestingly, there are 4 separate door modules on that one (vs only 2 in 150). Her previous mache (2024) spent 2 months in the shop due to issues with door handle, so I might want to keep those ones up to date.
rugedraw
Javier
Miami
Auto Sales
CMR will most likely take 45-60 minutes on the Mach E too. I've done a CMR update on a Mach E with my 20amp power supply and it was fine, but to future proof yourself whenever an IPMA update comes out, I would just go with the bigger one.
tompken
tompken
Tom
Miami, FL
Got the 100A charger with 8AWG cables, will start with smaller upgrades first to make sure they don't get too hot.
It seems I'll need to remove the 2 frunk panels to get to 12V. I'm connecting to those exposed posts and not the battery directly, right?
mredwin25
edwin
south florida
2021 f150 xlt
Used one like that, worked perfectly and also works for my 911 gt3 if I’m doing any coding
tompken
tompken
Tom
Miami, FL
Got the mache upgraded, no issues except for the "Stop safely now" popping up on the dashboard... All DTCs are gone, every module showing green, and yet still this message won't go away. Not sure what to do with it.
rugedraw
Javier
Miami
Auto Sales
You'll want to connect the negative to the BMS sensor
Message me the VIN and I'll check it out tomorrow.
tompken
tompken
Tom
Miami, FL
I did message you, however after keeping the car off for 30 minutes, the error went away. Fingers crossed it stays that way.
UPDATE: Drove it around this morning and so far so good 🤞🏻
