Its permanent unless you take it for maintenance and they turned it back on for some reason or the battery was unplugged then you might need to do it again. But otherwise it's a once and done.Are the 2 solutions above permanent or have to be repeated each time using the truck?
What did you do to get that removed cause I can't find the code to do that. I got it to where if it's on while driving and I take it off it stays red and on the screen and can't be moved till the belt goes back on.The chime doesn't bother me as much as the screen showing the green checkmark(s) on the cluster not going away until I hit the 'OK' button on the wheel. I wish that was able to be changed without forscan.
