2024 PB Seatbelt Chime
30snack
Brian
2024 King Ranch
All,
picking up the truck tomorrow. On all my previous F150’s there was a way to disable the seat belt chime without Forscan. Does anyone know that process for the 2024 PB? Thanks in advance
Rinn69
N Central IOWA
Retired USAF Medic
I just tried this on my 2024 XL and it worked. It didn't work for the guy, but he already had his turned off, so when he did it again, it turned it back on, so he did it again, and it worked.
Turn key on (do not start), turn radio/AC/fan off, set parking brake. Turn key off.
Turn key on (do not start), wait until air bag light goes out, wait 3-5 seconds, then buckle and unbuckle the seat belt 4 times, ending with it unbuckled, wait for seatbelt light to flash and then stay on, then buckle and unbuckle one more time. That's it !! You can drive it around the block with your seatbelt unbuckled and the warning on the screen will stay on, but NO CHIME !!
Beaux
Brandon
Georgia
2024 King Ranch
The instructions are in the owners manual on your center screen. It was easy to do. The 24 seat belt warning seems more aggressive than previous years. But I always disable mine.
nysteve
steve
Suffolk NY
24f150 303A PB,99e250Van,08GMarq,23 Camryhybrid
retired FDNY
Are the 2 solutions above permanent or have to be repeated each time using the truck?
30snack
30snack
Brian
2024 King Ranch
I’ll get back to you with first hand info…..in all my previous Fords it was permanent
Wookz
Shane
wisconsin
F150 XLT 3.5 ECO
Its permanent unless you take it for maintenance and they turned it back on for some reason or the battery was unplugged then you might need to do it again. But otherwise it's a once and done.
Goldeneye36
NC
2024 XLT Powerboost
The chime doesn't bother me as much as the screen showing the green checkmark(s) on the cluster not going away until I hit the 'OK' button on the wheel. I wish that was able to be changed without forscan.
Wookz
Shane
wisconsin
F150 XLT 3.5 ECO
What did you do to get that removed cause I can't find the code to do that. I got it to where if it's on while driving and I take it off it stays red and on the screen and can't be moved till the belt goes back on.
Thanks.
