FirstTimeFord
Are these Ford issues or Dearborn issues?
Dearborn issues are Ford issues.Are these Ford issues or Dearborn issues?
How did they fix the scratch?My hood gaps were off side to side as well. Took the shop a few minutes to sort it out. Now to fix the big ass scratch on the bed noted on the PDI.......
Well....they took the whole bed off to repaint the side panel. Replaced tail light with new after they ordered the correct one by engineering number.How did they fix the scratch?
This is true! ? Are they isolated to the Dearborn plant or are similar issues being found across various models and plants was my intended question?Dearborn issues are Ford issues.
I had a scratch on my truck. Took delivery 1 day short of a month later. (Arrived 8/15, took delivery 9/14) I don't know what they did, I just know it went in on 9/9 and was back at the dealer 9/12. Can't tell where it was and nothing seems out of whack.Well....they took the whole bed off to repaint the side panel. Replaced tail light with new after they ordered the correct one by engineering number.
Paint and peel matched perfectly. They also repainted the right front door. Then everything had to be recalibrated.
Then the detailers got ahold of it and put surface scratches on all the panels when they washed it
So it needed some paint correction after.
Took them 26 days to complete. Had a loaner truck the whole time. Glad it turned out to my standards, other than the amount of time it took to complete.
What is comical is my last two trucks were built in Dearborn. A lot of my rental trucks are from Kansas City. I think they have a better build quality.Are these Ford issues or Dearborn issues?
Mine came from KC and I haven't noticed any real problems with fit, alignment, stuff not hooked up, etc.What is comical is my last two trucks were built in Dearborn. A lot of my rental trucks are from Kansas City. I think they have a better build quality.
Good morning, Brandon! I would be glad to help you out with these paint/trim concerns should you need further assistance. Just shoot us a PM with your VIN and dealer name/location, and I'll get right on it. To send a private message, just click on our username and select "Start Conversation". Thank you!I have the same issue on my trim piece. Been replaced already and still the same. When it’s hot outside it flexes it more. Push it in and it chips the paint off of the fender…![]()
Did you ever get this fixed? My truck is having the exact same issueI have the same issue on my trim piece. Been replaced already and still the same. When it’s hot outside it flexes it more. Push it in and it chips the paint off of the fender…![]()
did you ever get this resolved? My truck has the same issue![]()
I have the same issue. Dealership has tried to fix twice now.It was in my purchase agreement that they would fix it. Dropping it back off to dealership mon. Will see what happens. You end up getting yours fixed?
my truck has the same issue. Can you assist with mine as well? Dealer wrote an “I owe you” at time of sale and still it has not been repaired.Good morning, Brandon! I would be glad to help you out with these paint/trim concerns should you need further assistance. Just shoot us a PM with your VIN and dealer name/location, and I'll get right on it. To send a private message, just click on our username and select "Start Conversation". Thank you!
