2022 - Bilstein 5100 possible steering issue?
jkw03svt
Jordan
WV
2022 F150, 2003 SVT Cobra, 2004 Ranger, 1985 F150
Construction Inspector
I installed my front and rear Bilstein 5100’s last weekend, the ride is great so far. Only issue I’m finding is it almost feels like the 4wd is engaged or slightly binding when turning, even though I’m in 2wd.
Has anyone else ran into this issue? For reference, I used the 4th shock setting out of 6.
Natetroknot
Nate
Dubuque, IA
2022 XLT 3.5 302A
Have you had it aligned yet, and if so, do you know your numbers…..specifically caster?
JIMFOUNTAIN
Jim
Austin, Tx
2021 F150 SCREW PB 6.5' 701A
And make sure you didn't bump the differential lock on accidentally.
jkw03svt
jkw03svt
Jordan
WV
Camber
0° / -.2°
Caster
5.7° / 6.1°
Toe
0.11° / 0.10°
12Lariat21
Jonathan
2021 Lariat 502A
Engineering Manager
Might want to make sure you got all bolts torqued properly, including the lug nuts.
Second I would jack up the front and see if you can free spin the tire, maybe it is somehow stuck in 4wd even though the indicators say 2wd....
I had mine installed and aligned by my Ford dealer (set at the 1.5" setting, don't now which setting mark that is...) Mine has always turned normal without any binding type symptoms in either 2wd or 4Auto.
jkw03svt
jkw03svt
Jordan
WV
Bolt check and checking the axles were the first things I did after noticing the issue. No issues that I’ve found.
I’ve actually been through it twice now doing torque checks.
12Lariat21
Jonathan
2021 Lariat 502A
Engineering Manager
Huh...I just can't imagine anything that would cause your symptoms except it being in 4wd...
Have you made a turn in 2wd then made the same turn in 4wd, to see if there is a difference?
Oilberta
2022 F150 XLT 302A 5.0 Sport Max Tow 6.5
Jack it up and turn the wheel ? , check if the axle moves with it, if so - look at the EWE’s.
Natetroknot
Nate
Dubuque, IA
2022 XLT 3.5 302A
What clip setting are you at? Mind posting a pic of your CV angles at ride height?
Which T case/trim level truck do you have? Do you have a 4Auto button?
Anything happen to a vacuum hose during the install? Did you install aftermarket UCA's? If you didn't get the room for install by removing the upper ball joint/UCA, then I assume the spindle was removed from the axles entirely during install? If so, how many ft - lbs did you torque the axle nut to?
Sorry for all the questions but there are more than one way to install your setup and the details will help provide you with some better ideas.
Buyer2021
central TX
retired!
Zero issues with 4-corner 5100 swap on 4WD 2022 Lariat, but I did keep stock / lowest setting ride height.
jkw03svt
jkw03svt
Jordan
WV
It doesn’t hop or really bind as if it’s fully locked in, just feels like there is a resistance when turning. Not in the steering wheel, but at the wheel itself.
jkw03svt
jkw03svt
Jordan
WV
3rd clip setting, I will post a pic of the cv axles this evening.
It’s an XLT so the front does not always rotate, no i do not have 4a.
Nothing happened to the vacuum hoses during install to my knowledge. Stock UCA. Yes, the axle was removed from the spindle for the install. Torqued the axle nut to 25-30 ft lbs.
I’ve went through everything I can possibly think of, it has me stumped.
jkw03svt
jkw03svt
Jordan
WV
I did this early on. Axle does not turn with it.
Natetroknot
Nate
Dubuque, IA
2022 XLT 3.5 302A
I doubt your angles are bad at that setting. Was just a thought. Alignment numbers look good. If your axles aren't turning when you jack it up in 2wd your IWE's are doing what they're supposed to.
It's been long enough that if something were hanging up and causing a bind, you might see it in your fuel mileage......any drastic changes you've noticed in that department?
I'm pretty much fresh out of ideas, and it sounds like you've triple checked for any install errors/issues. I'd say keep driving it, maybe cycle the 4wd once in a while on a nice straight shot of road, and monitor things. No other advice for you from me I'm afraid. Good luck!
