SilverPigeon
Welcome ?
It probably is unreal themes. Trucks are shipped with it now. Maybe you have a misunderstanding of real theme? @WookzMight be a dumb question but I have a 2025 lariat PB 502a and I tried adding unreal theme but the number that was currently in that slot was the one requested but it's not unreal theme?
Could the 2025s have a different number code for that and if so do we have the new correct code?
Also seatbelt deactivate code is also not seemijg to work as well.
Thanks for the insight.
You know what i looked at my Brother in laws and mine who i put unreal theme on and then mine, it's the same thanks ?It probably is unreal themes. Trucks are shipped with it now. Maybe you have a misunderstanding of real theme? @Wookz
What seatbelt shit? What coding are you using? are you talking about the seatbelt chime or the popup in the IPC? @WookzYou know what i looked at my Brother in laws and mine who i put unreal theme on and then mine, it's the same thanks ?
But the seat belt shit is the last of my changes along with adding heated and cooled settings now. Appreciate it.
Try hereDoes anyone know if it is possible to add Rock Crawl drive mode to a non-FX4?
what's that?FIX FOR THE DRIVER ID MESSAGE AT KEY-ON
Back a couple of pages: https://www.f150gen14.com/forum/thr...an-list-database-spreadsheet.1578/post-595718what's that?
re-run forscan clicking no to loading saved vehicleJust did the manual FDRS update of all of my modules and now notice that I no longer have 360 camera at speed (only options are bed, hitch, and rear view). I also have the black box in my rear view, which I never had before.
Went into Forscan and confirmed that I had the correct values for camera at speed (didn't have to change anything) and also went ahead and removed the black box.
Has anyone else experienced this? I did a search of the forums but struck out.
@HammaMan, just did it and checked the values for Enable Cameras at Speed and they are still correct but still no 360 camera at speed.re-run forscan clicking no to loading saved vehicle
