SilverPigeon
Australia
when i put the things in do I need to put the IPMA in first or the APIM or does it matter. also do i need to reset either one after i do the updates?
Do the IPMA first, you will then have something to see on the camera menu when you do the APIM after.
SilverPigeon
Australia
...Do you happen to know what module smart hitch is under and I could check to see if it has it on FORScan?
It's in the APIM. It should be in the trailer setup settings menus. In the spreadsheet, it's Autohitch. Depending upon whether you have the hardware to support it ?‍♂ I wouldn't worry about it now, but you can play with it when you have a trailer on. I have "F" but haven't played with a trailer yet.
Trailer Settings Feature (TSF) • Trailer Setup Configuration (TSC) • Trailer Vehicle Style (TVS) • Autohitch (A)
7D0-01-03xxxxxx*xxx--
SilverPigeon
Australia
Okay. Do I need to reset either one after I do the configurations?
If you don't see the 50-50 view on the camera menu, yes.
NickT_
Nick
Alabama
2021 Ford F-150 Platinum 4x4
I have a “F” also in mine. I will look into it later but I probably don’t have the hardware to support any of it.
NickT_
Nick
Alabama
10-4 I’m going to change everything in the morning since I’m still hooked up to the trailer to make sure it all works and try to figure out the other thing with the trailer setup
NickT_
Nick
Alabama
I was able to get everything working that I wanted! But good thing I doubled checked everything again cause the one where I thought it was a “E” I was looking in the wrong spot on the box and not the second number. All is well tho!
Cobraman428
Jerry
Tampa Bay Florida
VP of IT
NickT_
Nick
Alabama
What are some things you added to your truck that isn’t on the “common” tab?
Nightshade
AJ
Alberta, Canada
-DRL brightness LED bar boost (Lariat+)
-Seatbelt disable (values for this on spreadsheet won’t work on 2024 as it seems)
-Window auto up (auto down is already enabled from factory)
SilverPigeon
Australia
SilverPigeon
Australia
NickT_
Nick
Alabama
Can you add different ambient lighting in a 2021 platinum other than the standard single color?
I found 7D0-01-02 xxxx xxxx *x--
But didn’t know if 2021 has the equipment to do it.
22SpaceWhiteXLT
Chad
Tampa Bay
2022 Space White XLT Sport
I've started adding FORScan spreadsheets here for anyone interested: https://bit.ly/3cJnYMS
My FORScan tutorial is here: https://docs.google.com/document/d/1-8dKaS_Spu4Zw4hV_CrKC4tLoP9G8yejqegF1wxIqxY/edit
@Livnitup @Jesse-Infotainment
I am trying to find the most simple forscan changes to make my truck think I have a 6 speaker system not a 7 speaker. I have the dash center speaker unplugged due to adding a kicker Amp. It is throwing a code for that speaker and is causing the emergency beeps to come from the cluster. I had done this successfully a few months ago but after some updates at the dealership I think it got wiped out and now its coming from the cluster. For the life of me I cant remember what I changed to stop this from happening. I could have sworn there was an "easy" mode to change from 7 speaker to 6 speaker system but I cant seem to find it. Any help is appreciated!
SilverPigeon
Australia
@22SpaceWhiteXLT Chad, I haven't mucked around with the speakers before, but until you get more/better help, maybe try this change in the DSP: (if you have between 0 to 7, try its opposite; if you have between 8 and F, ignore this and don't change):
Ford F-150 2021+ F-150 FORScan List / Database / Spreadsheet IMG_4895
