Add Heating Steering Wheel to 24' XLT
Rob38
Rob
Ontario
2024 XLT
sheet metal worker
S would be 25.. so its totally possible they superseded
SL3Z3F791JA
THis is the part number I pulled
2024 is still showing
RL3Z3F791BA as a valid part number
I know.. it gets confusing. But all the heated wheel are for power column.. all you have to do it take the switch off.
THe auto wipers are the same.. all those have a different stalk. that has a extra graphic on it. It doesnt work though unless it is programmed and the rain sensor is there.
The 21 was the only one you had to be careful with because they had an active steering SCCM that wouldnt work in trucks with out but trucks dont have that anymore.
Rob38
Rob
Ontario
2024 XLT
sheet metal worker
are you still selling the harnesses, and will they work on a '25 XL
I can confirm that this part number given SL3Z-3F791-BA also works for me too. Ran the TRON and it went successfully less than 5 mins. Was able to do forscan to load the factory as built and used superfordman's sheet. Then I got a working heated steering wheel in......summer time.
hello! Did you have to get it authenticated through the dealership or was it ready to go? What about the clockspring? I’m desperate for a heated steering wheel and now I’m even more determined as my dealership says it’s impossible. Thanks so much
Rob38
Rob
Ontario
2024 XLT
sheet metal worker
Dealer only FDRS. NEVER will be available any other way
Let me make an edit. I never say never. I should clarify and say its unlikely.. BUT there is always a chance. THe issue is the agreement takes place on Fords end. It resets the keys and sets the keys in the modules that hold them.
THe Encryption is the big reason that the PCMs cant be tuned at the moment for a super charger or other performance.
One truck that does have a whipple on it the Cluster displays Certified Calibration to let the dealer know that it is indeed a Ford authorized tune.
We would have to really dig into the TRON process and do some things to be able to copy it but since it reaches out to Ford servers.. its going to be hard to duplicate.
Good morning! I’m loving all this info, I’ve got he wheel and wiring harness ready to go, got the SCCM info thanks to you guys🤙🏻 was wondering about the clock spring? Is that part of the SCCM? Thanks so much for your info already, amazing. Of course my dealership said it’s impossible so now I’m more determined
Rob38
Rob
Ontario
2024 XLT
sheet metal worker
SL3Z-3F791-BA is the right part. I was able to install one into my '24 XL this weekend. I copied over the forscan values from my original SCCM, then ran a PMI in FDRS and then I ran the the TRON network repair. Interestingly, the PMI and TRON process both failed, but the SCCM seems to work OK with no DTC's.
Morning, did you have to get this authenticated from dealership? Did you change the clockspring? I’m desperate for a HSW, I have the harness and wheel just figuring out the SCCM and clockspring, of course my dealership says it’s impossible which makes me want it more… thanks so much for any and all info
Curly
Curt
Mn
2024 F150 PowerBeast
Problem Solver
amazon has the power connector for the heated wheel part. See Posts 53 & 57 I emailed a dealer using this wording, $250 in Mn;
Wondering if the tec could use FDRS Diagnostic's to run the TRON to
authenticate the new SCCM I installed (heated steering wheel).
I think they only use the term SCCM no more clock spring.
Rob38
Rob
Ontario
2024 XLT
sheet metal worker
on has the power connector for the heated wheel part. I emailed a dealer using this wording, $250 in Mn;
Thank you very much
Weller12
Geoff
2025 F150 XLT
Ok big question here I want the actual button on my HVAC controls is there a controller that has heated seats and heated steering wheel without cooled seats?
if I have a cooled seats button I will be tempted to figure out how to add them.
TheDudeee
Samad
North Dallas, TX
2024 Ford F150 XLT
Sadly no. I know ford made them for few models but not for F150 and super duty. I belive that I saw somewhere that someone tried to put the bronco hvac module into the F150 and their F150 hate it that it throws all different sort of DTCs.
If you are going to install hvac module with heated and cooled seat buttons, it is not going to work beacuse you do need the DSM (Driver Seat Module) to send signals to cool or heat the seats.
