So an OTA has been going out causing a Wrench Light on the CLuster.
EDIT - So I seem to have gotten the fix this time.
If you have the wrench after the OTA then you will need Forscan
You will need to go to the PCM as build and make this change
7E0-163-04 XXXX XXXX 01XX
The OTA set it to 02.
Once you have made the change clear the codes and you will be set.
