flynnstone
Anyone have an easy fix - my passenger window has started squealing when rolling it down
Did you take the door apart and try and hit the track, or just spray into the window track from the top?This is what I used and it works like a champ not to mention the window goes up and down a lot smoother too. https://a.co/d/3Sp3tJE
Actually I had a different sound coming from the door originally(a flapping sound on rough roads) which I took the door panel off for and only put a tiny bit of lithium grease at the very bottom on each side. It was after that, that the window would squeal a little bit occasionally that I decided to try the spray. I used the spray liberally on both sides and even used the nozzle to get down in both sides and much as I could. If you spray a good bit in there it won’t have any problem getting all the way to the bottom.Did you take the door apart and try and hit the track, or just spray into the window track from the top?
Spray a little silicone in the guidesAnyone have an easy fix - my passenger window has started squealing when rolling it down
What are the guides? and where do you spray them? I have this issue on my drivers doorSpray a little silicone in the guides
The guides are basically the tracks on each side that the window slides up and down in. Just liberally spray down both sides.What are the guides? and where do you spray them? I have this issue on my drivers door
