What's your payload? 2.7 Lariat
dhrandy
dhrandy
Randy
Concord, NC
Engineering Tech
I have the sun roof, 2K Power on board, spray in bed liner, 502A package, auto tailgate with built in step.
Also, have the B&O Unleashed sound system.
I guess all that brings the total down from 1760 Pounds to 1218Lbs
542 pounds less - ouch
You have the record right now, lol.
TXENG89
Will
Dallas, TX
Here's my 5.0 501a Lariat equipped with Max Tow, FX4, and sunroof.
Ford F-150 What's your payload? 2.7 Lariat 20210802_151522
dhrandy
dhrandy
Randy
Concord, NC
Engineering Tech
Yeah, I have changed my order to the 5.0 to get more payload.
Predator
Billy
British Columbia
2021 F150 2019 Escape
2021 F150 Lariat Supercrew 145" wheel base 2.7L V-6 4x4
6600# GVWR Package
3.73 Electronic Lock RR Axle
1481 Pounds payload/passengers
IconicXLTsport
William
South Carolina
2021 Ford F150 XLT
Nuclear Operations
2021 CCSB XLT 302A (close to lariat equip minus the leather seats) 4x2 3.55
GVWR 6400, payload 1696
dhrandy
dhrandy
Randy
Concord, NC
Engineering Tech
Just for informational purposes, my payload is with the 5.0 is 1925.
Ford F-150 What's your payload? 2.7 Lariat 1636507479409
GregBC
Victoria, BC, Canada
2022 F150 XLT 5.0L 302A Carbonized Gray
Retired US Navy; currently DND
I'm really wanting to stay with the 2.7 and wanting to get a small travel trailer around 5000 lbs. I wouldn't be too concerned if the advertised payload was close to the actual, but it seems to be all over the place. I'm looking at a Lariot 400a 4x2 and want to see if anyone has any real world payload numbers. I'm not getting any of the tailgate, power bed options, or sunroof which should yield higher payload numbers. I'm concerned that I might need to bump up to the 5.0, which I really don't want to do
I know this has been talked about some in other subforums, but I'm looking for 2.7 specific numbers.
Update: The reason I'm concerned about payload is that I plan on buying a camper that weights around 5000 lbs (probably a little less). I have a spreadsheet where I can calculate the needed payload based on worse case scenario. Attached is the payload chart from the brochure. FYI, you'll never see max payload when you option out a truck. (Check the truck sticker with the tire information for payload).
Started a spreadsheet, the more information I have the better.
I notice there are two GVWR values for some options (like 2.7L 4x4: 6600 & 6900). How do you know /choose which GVWR you'll end up with? Is the higher value a result of the Heavy Duty Payload Package for the 2.7L that I see as an option?
dhrandy
dhrandy
Randy
Concord, NC
Engineering Tech
Yes, that's with the Heavy Duty Payload Package. That chart is actually from the brochure. I ended up going with the 5.0 and have a payload of 1920 lbs.
Ford F-150 What's your payload? 2.7 Lariat 1645493616732
ks54703
Ken
Central Wisconsin
22,XLT,302a,2.7EB,19, 2.0EB Escape,79 Magnun GT. 05 Magnum RT
Retired IBEW Local 14 inside wireman
There is no HDPP with a 2.7.
HDPP is only available up to the 301aXLT with either the 5.0 or 3.5EB
6900 # on the 2.7 EB requires the # 1 option, the 2.7 EB payload package.
The XLT 302a is the highest trim the 2.7 EB payload package (6900#'s) is available on.
All Lariats are at 6600#s
2.7EB payload package increases payload to 1965#'s from 1740#'s on the 4X4, 145" Screw.
{tpc}
Anthony
Berkley, MI
I wouldn't be concerned with your 5000 lbs trailer. My 2018 2.7 performed great pulling a 5000lb trailer. That was a actual weigh in at 5000 lbs. With the 2.7 4.2 screw, your looking at Max trailer weight of 7700 pounds, which your well within. Tongue weight at 15% would be 750, so if you add in a hitch of say 125, your at 875. If your payload is at 1400 (just pulled this number from thin air) you still have 525 left. I don't know what actual curb weight is, lets call it 6500 pounds. 6500 +5000 = 11,500 plus your extra payload leftover at 525 = 12,025 combined weight, which is still under 12,800. So looks to be good?
Forgive me if I did the math wrong, i'm sure someone will correct me. Also, nothing is certain until you hit a scale with everything, but theoretically it seems to be ok.
GregBC
Thanks - mis-typo on my part! "2.7 Payload Package" is what I meant. Crazy-confusing regardless, haha.
My understanding is then the 1965# is then the absolute MAX and just about any option added will take away from that value. Still a pretty decent number, from what I've seen online with higher-end F150's and Tundra's. (one video highlighted that a Maverick had a higher payload than any of the F150's in that video, which were all in the 1500-1600# range; not too shabby!)
Cb Mw
Brett
Minnesota
Bike
I have not received my order but already starting to second guess the decision due to payload. Family of 4 and don't currently tow anything, possible a small boat or trailer in the future. More than likely it will be a family hauler and grocery getter; maybe this is an irrational worry I'm not sure.
2.7 Lariat 500a, trailer tow package, bed utility package, 36 gallon tank.... (no sunroof)
Bobbert
Phoenix, NY
2021 F-150 Lariat Sport, SC, Iconic Silver, 2.7
Shleweeh
F89
Oregon
2016 VW Jetta,1995 Mazda MX5, 2022 F150 Lariat
6600# GVWR Package
Do you have a moonroof?
