Seahawk51
It is a duplicate of your the key in your key fob. It locks/unlocks the door, the center console storage, and the lower glove box.
Very trueProbably not, but I'm willing to bet that the magnets will still stick to the framework.
Looks like the key for the locking device for the under back seat storage area.
This is what I was told it was for.does the lower glove box lock? maybe for that
I was told valet key also. It would be interesting to see if you unlock the door with the key would it allow you to use the push button startMine was on the upper dash.
Texted my salesman. He said valet key. Ummm, dude, push button start. ? And, valet key is designed to NOT work in anything but door and ignition.
Keyed the same as key in fob. Maybe backup if you lose keys and need one cut. But, computer has that info. So, can only imagine it does give ability to use force on spare tire hole if needed.
So surprised Ford dealers/salesmen don't even know it exists. ?![]()
I believe there is a chip in the key otherwise it would be useless other than getting in the truckI was told valet key also. It would be interesting to see if you unlock the door with the key would it allow you to use the push button start
ok. Good to know. I should just try itI believe there is a chip in the key otherwise it would be useless other than getting in the truck
What key are we talking about? I thought we were talking about the key that you take out of your fobThere ain't no chip in that key. Flat piece of metal. It will open the spare tire hole and you can put pressure on it if needed unlike the key in the fob. Only possible thing I can think of.
