What is this? Shouldn't they be capped if not in use?
JJSnell
JJSnell
CdA, ID
2022 F150 Platinum FX4 PB
2022 Plat PB.
Was under neath the passenger side front seeing why my tire was rubbing when I saw these two open wire connections. Considering the proximity to wheelwell and pointing straight at the ground, shouldn't these be capped if not in use? What do they go to? And besides using crude electrical tape, anyone know the exact plug part number so I can properly cap...?
Ford F-150 What is this?  Shouldn't they be capped if not in use? 20230316_154347
Ford F-150 What is this?  Shouldn't they be capped if not in use? 2023-03-16 15_56_14-(2) What is this_ Shouldn't they be capped if not in use_ _ F150gen14.com
EBR
MN
07 Lincoln Mark LT, 23 F-350 Platinum Diesel
Double check them. The pict seems to show that they are the caps.
JJSnell
JJSnell
CdA, ID
Ok will do... Maybe they are? Eyes are not getting younger. Any idea what it goes to?
EBR
MN
Sorry, don’t know where they go nor what they are for.
Pelican
2024 F-150 Lariat (502A) Supercrew POWERBOOST
Financial Management
2022 Plat PB.
2023-03-16 15_56_14-(2) What is this_ Shouldn't they be capped if not in use_ _ F150gen14.com ...jpg't they be capped if not in use_ _ F150gen14.com ...jpg
Just spare parts?. Don't worry about it. Just kidding. That's interesting. Now I'm going to go look at my truck. Thanks for posting JJSnell
Aron
Aron
Civil Engineer
I think that's correct. Ford seems to use unpopulated wiring connectors as caps for these types of unused wiring harness connector points.
JJSnell
JJSnell
CdA, ID
My take is that Ford uses one (or a few) wiring harnesses and if you didn't get some options the wiring is still present.
It's a Platinum PB so I'm not sure what options I could be missing? Maybe it's the electrical switch for my hydraulic airs shocks when I want that '63 Impala bounce????
In all honesty with LEDs maybe it's the Halogen lead? I would think that would terminate closer to the headlights?
Just strange. I'll crawl underneath today and try and get better\clearer pix.
I don't believe a Platinum gets the CCD suspension by default.
I'll see if I can get some shots of where the connectors are for the front of the truck.
JJSnell
JJSnell
CdA, ID
Leave it to Snake...
This would make sense and no I don't have the CCD, had to look up what that even was.
And yes Big Dog was also correct, closer look shows those actually are caps.
Ford F-150 What is this?  Shouldn't they be capped if not in use? 20230317_100800
Ford F-150 What is this?  Shouldn't they be capped if not in use? 20230317_100846
Could be for the locking hubs too which are no longer on 22s and 23s 4a trucks.
