What is this mystery part that fell off my truck?
Sentinel1201
DFW
2021 F150 Powerboost
Found this hanging on to my exhaust. Any idea where this heat shield should have been?
21 powerboost.
Ford F-150 What is this mystery part that fell off my truck? PXL_20210822_005056419
Pete6114
Pete
Ontario Canada
2021 F150, 2023 Lincoln Aviator
Retired Ford employee
it was stuck underneath middle of the box above the driveshaft area. don't know it's purpose though..Mine's not sticking very well either and will fall off before to long.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Looks like sound proofing material that is usually stuck to the inside of the cab.
Sentinel1201
DFW
Could it have been stuck to the hybrid battery? The bottom of the battery is textured/ridged so I can't imagine this would have stuck to it. But curious if it was meant to keep heat away from battery.
12Lariat21
Jonathan
2021 Lariat 502A
Engineering Manager
The foil/shiny look actually reflects a lot of Infrared heat, so if the shield is to protect a battery, It would be in your best interest to make a warranty claim with your dealer. Don't just ignore it
Gunny
2021 F-150 Plat
That is the sound proofing panel that is fixed above the drive shaft U Joint. I just had to take mine to the dealership to get them to apply more adhesive as mine was falling off and hitting the drive shaft.
The dealership just used 3M double sided tape to put it back in place.
Ajzride
Automation
Can you please post a picture of yours as it stands now? Would help to know exactly where this was located originally so I can reapply.
I'll second this request, mine has fallen off and i'd like to make sure I put it back in the right spot.
macsinbragg
bragg Creek Alberta
2016 f 150
Yup, it is just above the driveshaft on mine. It fell down last week and had me worried I needed a new transmission. Just put it back up and underneath another het shield and seems to be staying.
apMechorse
Steve
Fargo, North Dakota
Mine was like that when I picked it up. I just pressed it back into place and it's stayed there since.
If its the same piece it has nothing to do with the battery or with the cab.
Ford F-150 What is this mystery part that fell off my truck? exhaust
Ford F-150 What is this mystery part that fell off my truck? PXL_20210330_212811490
imnuts
Dirty Jerz
'21 502A Powerboost 4×4
Facilities Engineer
How did people fasten theirs back up? Mine fell off too, wasn't sure what exactly to use to glue it back in place.
SuvE
Gary
Arizona
I used spray adhesive to fix mine in place. Pull it down, spray both the insulation and the underside of the truck, wait about 30 seconds and press them together firmly. It's been fine ever since.
CardsFan
Tim
Kentucky
2021 F150 XLT SuperCrew
This is why I love this forum. Over the weekend, I was hearing an odd sound coming from what seemed like under the vehicle. It was the first time towing our camper so I was afraid that I had caused some damage somehow. After reading this, I looked under my truck and found a piece of this sound/heat shield resting on my drive shaft. I wedged it up under another piece but will look for a more permanent solution. I did schedule a 1 hour session at the Service department at the dealership to get this fixed permanently.
Thanks everyone!
Bird of prey
Co
2021 F-150 King ranch power boost
The heat shield came off the bottom of the bed just above the axle where The exhaust pipe goes over the axle. Went to the local dealership had to order it was on back order for a while. Clean the bed peel and stick. They allowed me to take it home and put it on myself
Ford F-150 What is this mystery part that fell off my truck? 6C00AA40-031E-4C69-9EE3-4D25959AB883
