What’s the flat key for?
BoilerTimmay
Tim
Indiana
2011 SCREW 3.5L
I got a flat key, what is it used for? Haven’t found it in the manual. Thanks.
Wishiwas
New Hampshire
2021 F-150 XLT
I'm not sure which key you mean, but I believe its to lower the spare tire (key socket next to hitch) or to unlock door in the event of a dead battery or to lock the back seat in the down position. If equipped the lock is on the panel near the floor when you first open the door.
Ford F-150 What’s the flat key for? cq5dam.web.1280.1280
snoshuu
Paul
Earth
2021 F150 XLT FX4/Sport(302A) -5.0- Velocity Blue
Troublemaker
Center Console / Glove Box Lock
I also found that same key and can confirm that it does indeed lock and unlock the center console and glove box.
BoilerTimmay
BoilerTimmay
Tim
Indiana
2011 SCREW 3.5L
Amazing that I can’t put it on a key ring then. I wonder if I can copy it.
BoilerTimmay
BoilerTimmay
Tim
Indiana
2011 SCREW 3.5L
Where did you find this flat key?
It was in the packet of paperwork.
I have confirmed that it is the same laser cut as the keys in the fob so it’s a spare for that.
cakryg
NY
2004 Tundra
I discovered that you need the flat key to access the spare tire access hole to the right of the rear license plate. You need to remove the lock cylinder to lower the rear tire.
Touchdwn
Doug
Keller, Texas
2021 F150 Limited Power-Boost; 2018 Honda Odyssey
Corporate Pilot; retired Air Traffic Controller
It will also work for the console lock.
PaulGrun
United States
2022 F-150 XLT
Ok I'll have to look for mine
Mine was on the shelf on top of the dashboard where you'd never ever see it, unless you looked through the windshield or something. I found it entirely by accident when exploring my new truck I swept my hand over the dashboard ... "WTF is this...?"
Beef_Stew
Aaron
2022 F150 XLT sport CCSB 5.0
Auto Body Tech
I had the same reaction. Only mine was in the bottom cubby of the drivers door panel
jeffcrum
Lake Saint Louis, MO
Computer programmer
Your key fob key will do that too.
The flat key is cut the same.
guppydriver
Aaron
Utah
2020 Tundra
I have the same post a few down. lol
Found mine in the bottom of a cupholder. It doesn't do anything your regular key can't do, plus no way to put on a key ring, so I don't really get it.
Someone mentioned in my post that it would be good for sending someone in your truck to get something from a locked glovebox or console if you didn't want them having access to driving your truck. I just can't imagine a scenario where you'd let someone in your locked areas without trusting them to have a normal key.
Mine is going in a junk drawer.
