Yes I remember seeing this on another post a while back.Anyone else seeing this? I was wondering why my door wouldn't close right and saw that it's missing pins to keep the weather stripping in.
Hi there. Go ahead and send us a private message with your truck's VIN and approximate mileage. I’ll look into this stripping concern for you on my end. Thanks!Anyone else seeing this? I was wondering why my door wouldn't close right and saw that it's missing pins to keep the weather stripping in.
Same thing happened to mine. I just stopped by the dealer and asked if they had a part available. They didn't have exactly the same part but similar enough to insert the pin and put the weather strip back.Anyone else seeing this? I was wondering why my door wouldn't close right and saw that it's missing pins to keep the weather stripping in.
I'm having this same issue. There only a clip at the top and bottom. Now my seal is getting misshapen. I just eat to know where I csn get the clips and I'll just fix it myself.Anyone else seeing this? I was wondering why my door wouldn't close right and saw that it's missing pins to keep the weather stripping in.
Is there a part number you can just point us to?Hi there. Go ahead and send us a private message with your truck's VIN and approximate mileage. I’ll look into this stripping concern for you on my end. Thanks!
Yep this worked!! That’s the correct part number.My 2022 only had like 2 pins in from the factory. Dealers around me said they couldn’t even look at it for like 4 days and I would have to drop it off cause they couldn’t do appointments. Honestly, ford needs to get their service figured out. After looking forever, I finally found a part number for these tiny pins. I haven’t got them in yet but are ordered. I will update this post once received and confirmed. Should be here next week.
Auveco #25472
Hope this helps someone.
Thank you for this, realized mine was missing some of these retainers as well. Any chance you know the part number for the retainers that go into the four brackets that are on this same weatherstrip part? Two of mine are loose so I’m thinking I might replace those while I’m at at itMy 2022 only had like 2 pins in from the factory. Dealers around me said they couldn’t even look at it for like 4 days and I would have to drop it off cause they couldn’t do appointments. Honestly, ford needs to get their service figured out. After looking forever, I finally found a part number for these tiny pins. I haven’t got them in yet but are ordered. I will update this post once received and confirmed. Should be here next week.
Auveco #25472
Hi there! Will you send us a message with your VIN and your local Ford dealer? I can look into things on my end.Thank you for this, realized mine was missing some of these retainers as well. Any chance you know the part number for the retainers that go into the four brackets that are on this same weatherstrip part? Two of mine are loose so I’m thinking I might replace those while I’m at at it
