Water in passenger door
Kangio
Philadelphia, PA
F150 PB Platinum RR BAP in production 4/5/23
My truck is usually kept in the garage, but had it parked on the driveway with some heavy rains. Now, driving the car, I can hear water sloshing back-and-forth in the front passenger door. I assume this isn’t normal? Any thoughts?
Kangio
Kangio
Philadelphia, PA
Actually, on closer inspection, it might be in the frame below the door…
Cheeeese
Anthony
New York
2023 F150 XLT
Picked up a new 23 last weekend.. got it home and found ice in the right rear door cubbie. Not sure where it’s coming in from though. Spends nights in the garage now.
Big Dog Daddy
New Jersey
Your door drains are probably clogged. There should never be standing water in the doors
Did you get underbody coating on the truck? Might have sprayed drain holes closed if it is below door.
DeancNYC
Dean
Staten Island, NY
2023 F 150 Lariat
Chief Engineer
HAd this happen on my 2012 Expedition. Door drains were clogged.
Kangio
Kangio
Philadelphia, PA
I did have the underbody sprayed. Must’ve clogged the drain holes. Is there a good reference on where I can find them to unplug
Old Hat
IL
Maybe see if you can inspect a new truck at the dealer. Should be easy to find when new and clean.
Is it in the door or in the body panel below door?
The other concern in addition to opening holes as needed is how the water got there if it is in body panels. Doors always get water in them just by design happens on every car but should quickly drain out bottom.
Kangio
Kangio
Philadelphia, PA
I believe it’s the body panel. I think my best best it to take to my dealer and have them take a look. After driving the truck, it sounds like a lot has now drained out, I don’t hear as much, but I do not want to have rot issues down the road.
Billflangjr
Tampa Florida
2024 Tremor
Check your drain hole's , stick something up in them, see it water come's out !!
