Various Recalls and Results - Including Rear Camera Screen Software Update
BobWadd
Bob
2021 F150 Lariat - 3.0 PSD - 502A - CDN
A few weeks ago, I brought my truck in for three recalls...
Rear Axle Half-Shaft and Hub Assembly Replacement
Axle shafts have been ordered, and truck was returned to me as neither hub bolt was broken.
Sunroof Air Deflector Inspection
No issues found.
When I picked up the truck the first thing I did was check the SYNC version. It had been updated to 24127-1270. It was 23291-1049 before being dropped off. As some of you already know I purchased a Mongoose cable in July of 2024 to bring the software up to date with FDRS. Update log showed that 10.1.1 TCU update had been performed.
I now have an occasional headlight warning, I have DTCs relating the level sensors. They were not there before bringing the truck in. Ford will look at it when I bring the truck back to replace the rear axle shafts. Headlights still perform as intended.
I only noticed one change from this update. The location of the directional indicators had moved to the upper outside corners as shown in the picture below. The red dots I added show the approximate old location of the indicators. I am not a fan of this new location as with my seat/steering wheel setup the wheel blocks the view of the indicators. I have adjusted both as much as I can and still remain comfortable.
Ford F-150 Various Recalls and Results - Including Rear Camera Screen Software Update Directional Indicators
The following weekend I made a few changes with ForScan that updated the adaptive cruise setting from 'Speed Sign Recognition to 'Predictive Speed Assist' with no results.
A few days later I received 25.2.1.6.5 APIM update. Did not notice any changes at first. A few days later I was using the ACC and noticed that the truck slowed down before a speed limit reduction. Proceeded to check the SYNC version and sure enough it had been updated to 25094-1779. Below is the IP indicator showing the new box that pops up when the truck is slowing down before it has reached the reduced speed limit sign.
Ford F-150 Various Recalls and Results - Including Rear Camera Screen Software Update Predictive Speed Results on IP
I believe this function is also supposed to reduce the speed before certain corners.
Now if I could just get the rear parking sensors to function again and activate the front ones I installed in July of 2024. This issue happened with the previous FDRS updates. Work has just kept me to busy....
BobWadd
BobWadd
Bob
After being stuck in a traffic jam today I discovered that the stop-and-go ACC feature no longer works. It worked fine before dropping of the F-150. As we have a lot of accidents here in Florida, I use the SnG feature quite often. I'll look into the cause as time permits.
