Upgrading Reverse Lights
ghowse
Geoff
St. John’s
I upgraded my headlights to led and decided to upgrade my reverse lights as well. I bought WT21W bulbs as that is what my research determined I needed. The bulbs I bought were listed for 2021-22 F150 reverse replacement. When I took the tail light off, there is a plastic panel with a flat white piece underneath. I’m guessing that is a bulb of some kind? Is this an led? Thanks!
Ford F-150 Upgrading Reverse Lights B7A95BFE-C1BB-461E-8916-B6A51A5873ED
Ford F-150 Upgrading Reverse Lights 7F41C422-044A-4858-8850-DDA355806FFD
Ford F-150 Upgrading Reverse Lights C0CE7A11-C799-475E-84FD-2A7F05E625A7
dolsen
KY
2022 Rapid Red 701A
I'm pretty sure that is the BLIS sensor
ghowse
Geoff
St. John’s
Blis sensor? Would that be for back up proximity alarm/auto brake?
Porpoise Hork
Bret
IT Sys Admin
Yep. BLISS = Blind Spot Information System . That's one of two sensor panels in the rear tails.
I'm pretty sure the reverse lights on BLISS equipped models are already LED. Only the parking,brake/turn are halogens.
dolsen
KY
2022 Rapid Red 701A
It may work in tandem, I’m not sure, but there are back ups sensors in your rear bumper as well. Those are the sensors that tell you when someone is in your blind spot, which causes the little orange light on the mirror to come on
ghowse
Geoff
St. John’s
Gotcha! Is the reverse bulb inside from the BLIS? I couldn’t see how to get at the bulb.
JCM
Ontario, Canada
2021 F-150 XLT 302A Sport
The halogen tails with BLIS already have LED reverse lights, and they are integrated modules so you cannot replace them.
I agree they're inadequate, so I've added these pods/harness to augment which is a massive improvement: https://specialtyperformanceparts.c...reverse-light-kit-no-drill-srl-rear-light-kit
There are many brands of pods that will help in this area. I liked the look and spread of the Rigid SR-L and they've been quite effective but I'm sure others are good too.
ghowse
Geoff
St. John’s
Ok, thanks for the info. I'm considering the license plate led that I saw someone had hooked up to their trailer plug. I can't have anything that hangs down. I drive through snow banks and plow my driveway. They wouldn't last long.
Is the WT21W any good for the upper brake light? It's a white light, not red. 13v, not 7v as well.
