pretty sure the caliper mount for the max tow axle has three bolts, standard axle has two bolts. Can you explain how they got around that? Am I wrong? Does the max tow bracket only have two as well?Someone bought parts recently -- needs rotor, caliper, caliper mounting bracket and the pads. Updated post 2 of this thread w/ the info.
Axle not needed
Same thread just highlighting specific posts in it.pretty sure the caliper mount for the max tow axle has three bolts, standard axle has two bolts. Can you explain how they got around that? Am I wrong? Does the max tow bracket only have two as well?
My goal with this swap was to keep my rear brake temperatures more reasonable by installing larger 350mm x 24mm rear rotors which should act as a better heatsink than the stock 336mm x 20mm rear rotors.
