Uneven Factory Brake Pad Wear
Antimatter_KingRanch
Minnesota
2022 F150 King Ranch 3.5PB FX4 Loaded
Program Manager
Took my truck in for it's second oil change yesterday, and the brakes are wearing unevenly.
The front driver's is at 3-4 mm; the rest are at 10. The truck is about to hit 15k miles, maybe 300 miles of towing in it's life. Not driven hard.
Anyone had a similar issue on a powerboost? I know the answer is generally an incorrectly installed pad or bad caliper; But I wasn't sure if the regenerative braking was creating issues.
Taking it back in a couple weeks once I can get a rental.
JIMFOUNTAIN
Jim
Austin, Tx
2021 F150 SCREW PB 6.5' 701A
Most of the time this problem is caused by a bad caliper or an installation issue.
Regen braking is rears only (unless in 4WD).
Gros Ventre
Western Wyoming
Do you drive interstate highways alot? If you do, when you exit it is usually a right turn with a slowdown from speed. That puts more of the stopping load on the drivers side front wheel.
Minnesota
Program Manager
Not any unusual amount. Probably fairly even split between city/local & highway miles; when I'm on the highway it's not a lot of getting on/off rapidly.
Minnesota
Program Manager
Thanks, hopefully that simple then.
Minnesota
Program Manager
K, probably then a caliper problem. Would think you have a stuck piston...
Easy enough fix at least, I'll see what happens in a couple weeks. Thanks guys
Calson
Monterey CA
2022 F-150
I would have the dealer check the pistons and the rotors. I had warped rotors at only 22K miles with a Chevy Tahoe and 90% of my miles were on the freeway. Replaced them later with after market rotors that were far superior to the factory ones. I put another 130K miles on the vehicle with no brake problems of any kind.
The initial brake break-in period is important and if someone ignores it they are going to have problems of their own creation.
