Underbody trans shield torn - replace?
matthewstn
Richmond, Virginia
2021 F150 Lariat Powerboost
Tore a corner of this fabric/cardboard material shield pictured below. I have circled the four mount locations in red. Looks like it may either be for aero or to shield the transmission from water or debris. I am wondering if it is worth replacing. If it is strictly for aerodynamics, I am going to wait and see if there is an actual impact to my fuel economy before replacing. Thoughts?
Ford F-150 Underbody trans shield torn - replace? IMG_5789
Ford F-150 Underbody trans shield torn - replace? IMG_5793
Kanuck
Winnipeg, Manitoba
Retired Electrician
I just epoxyed the corners that ripped back on. Think about getting a small fiberglass repair kit and strengthening all mounting points.
Bbf150
Brian
Livonia mi
'24 f150 XLT powerboost
Retired environment engineer
DDoes any know if a 2024 powerboost is supposed to have one? It doesn't look like one was ever installed on my truck.
KBKEITH
Probably not. My brother’s ‘23 didn’t come with one and my ‘25 doesn’t either.
My former ‘22 started to fall off so I removed it and never looked back. Seems they all fall off at some point. One less thing to deal with when doing an oil change. ??
powerboatr
North East Texas, Piney Woods
2024 F250 King Ranch Chrome
Retired Navy Senior Chief
I put the tremor raptor metal plate on
There is a thread on here
Ford F-150 Underbody trans shield torn - replace? 20230301_114915
Ford F-150 Underbody trans shield torn - replace? 20230228_155949
Bbf150
Brian
Livonia mi
gh8toes
Traded my '19 platinum for a 2024 King Ranch
Same thing happened on my '19 Platinum. I cut a couple pieces of 1" wide strip aluminum about 2-3" long, drilled a hole in both ends, then used large washers and bolt/nut to sandwich one end of the strips further back on the felt and used the hole on the other end as mounting points. Worked for me. My '24 KR doesn't have one.
Mt.F150..
Kevin
California
24' f150 xlt supercrew 4x4 5.0
If you plan on keeping the truck for a long time I'd put a tremor skid on it and call it good. Not sure why ford puts crap like that on their trucks
Mt.F150..
Kevin
California
markh
mark
Egg Harbor N.J.
2021 Ford F150 Lariat Supercrew 3.5l Ecoboost
I put a piece of aluminum channel across the whole back, riveted along the way about 8" apart and bolted through the aluminum to the mounts.
bandyrdk
Ford F150 2021
Mine tore on my 2021. I bought a can of Bondo fibre glass reinforced body filler. I put a layer of Bondo, added 1/4" fender washers on both sides and Bondo over that. The Bondo was about a 2 1/2' to 3' square over each hole. I tried to leave a dimple at each hole so they could later be drilled out to 1/4" or whatever you desire.. I then replaced the clips on the frame for fasteners with holes for threaded bolts. I maybe had a total of $40 into the repair. Its still in place. Been about 6 months. I cleaned the edges with a small rotary file in a die grinder. Made a clean looking repair. I also put retainers on the bolts so they stay in the hole when the diaper is removed during service calls.
Gord0
Gordon
2021 Lariat 502a
I put the raptor pan on my 21. Along with a PPE deep pan. No fear of a stick putting my truck out of commission now.
