Unable to program HomeLink with gate opener
Ruben
223 Ford F150 Lariat Black Ops
Insurance sales
Tried step by step repeatedly with no results. I got it to work on my previous vehicles. Any suggestions?
FirstFord
South Central Missouri
I tried a dozen times to program mine. Finally gave up and went with the old fashioned visor-clip buttons. I wondered if maybe my openers were too old(????).
Kanuck
Winnipeg, Manitoba
Retired Electrician
I don't think so.....my openers are 16 years old and it programed. I added it to my XLT.
Don't follow Fords directions...I think..I use Homelinks direction off the internet. Sears and Chamberlin openers
Ruben
Insurance sales
I guess I’ll have to do the same. Strange how I had no problem programming my 2021 F250. Oh well
FirstFord
My openers are 23 years old, which is why I thought that could be the reason. Using the Homelink instructions instead of Ford's is a great idea!
Aron
Aron
Civil Engineer
Do some searching on here—someone described the process to set it up back a year or two ago. I do remember that the process described in the manual isn’t 100% correct. If memory serves, the manual gives you a couple options to go about it, when in reality you need to do both options for it to actually take.
Bulldog
Minnesota
2021 F150 XLT, 2024 F150 Lariat on order!
Ford directions did not work for me either. I used Homelink instructions on YouTube and got it programmed
Ruben
Insurance sales
Thanks! Il
skiteton
IN
2024 Lariat PB | 2022 Explorer ST
Years ago, I couldn't get an opener to program with Homelink. The issue was on the opener's side; it had too many remotes/Homelinks programmed to it. I performed a "factory reset" on the opener and voila!
It may be worth checking yours to see if there's max number of remotes it allows.
Ruben
Insurance sales
I’ll look into that.
Thanks Skiteton!
Xman
N Texas
2024 F150 Lariat PB 7.2k
It doesn't matter which instructions I use, my 2024 will not link to my garage door opener. Will have to reset and try again, skiteton.
beaver24
Missouri
21 F150 Lariat
Engineering Technician
My 21 Lariat will not work with my Overhead Odessy 1000 openers. I've tried every option. Erase all codes, handheld transmitter then learn on opener. Nothing works. My wife's kia took 2 minutes and worked on the first attempt. Maybe mine doesn't actually transmit and I need to check or replace something.
Kanuck
Winnipeg, Manitoba
Retired Electrician
Follow the directions on Homelink.s web site to program....Ford doesn't seem to work. I added Homelink to my truck and use their directions to get it working.
Fordphanatic
Boothwyn
2021 Platinum F150
Union Carpenter
No issues with chamberlin wall mounted opener connecting to homelink.
